Graphically determining the focal length of a converging lens
The discussion revolves around graphically determining the focal length of a converging lens using the lens formula, specifically the relationship between object distance (do) and image distance (di). Participants are exploring how to extract the focal length from a plotted graph of the data points.
  • The original poster attempts to rearrange the lens equation into a linear form for graphing but expresses uncertainty about the process. Some participants question the appropriateness of the graph plotted and suggest considering the accompanying instructions or data collection methods. Others inquire about the specific problem statement and what has been attempted so far.
The discussion is ongoing, with participants providing guidance on the interpretation of the graph and the relevant equations. There is a focus on clarifying the correct approach to plotting the data and extracting the focal length, but no consensus has been reached on the best method yet.
Participants note the importance of understanding the problem statement and the data provided, as well as the need to adhere to homework guidelines. There is an emphasis on ensuring that the graph accurately reflects the relationship dictated by the lens formula.
ilovemycat
Graphically determining the focal length of a converging lens by graphing the given object distances (do) and image distances (di)
1/f = 1/do + 1/di
So I have plotted all the given data points on a graph, putting 1/di on the y- axis and 1/do on the x-axis. I have to now find focal length from the graph? I'm not sure how, I'm thinking I have to rearrange the equation 1/f = 1/do + 1/di into y = mx + b form then go from there, but I'm totally unsure how to do this. Can anyone provide guidance? Thanks
yes, i have not been asked to provide a ray diagram. heres the graph i made:
unsure how to find focal length just graphically...
There must be some kind of instructions that accompany these data whether they were provided to you or you collected them doing an experiment. What are these instructions?
It would also help if you provided a table of values instead of a graph. The graph you provided shows di as a function of do. What makes you think that is the right things to plot? Look at the "relevant equation" that you posted and think what you must plot to extract the focal length from the numbers you have. Remember that the focal length is a constant independent of di and do.
ilovemycat said:
Homework Statement: Graphically determining the focal length of a converging lens by graphing the given object distances (do) and image distances (di)
Relevant Equations: 1/f = 1/do + 1/di
It appears that you have been given set of object distances and image distances. It stands to reason that each image distance is paired with a particular object distance. From each pair ##\displaystyle \left \{ d_o\, ,\, d_i \right \} ## get the ordered pair ##\displaystyle \left ( 1/d_o\, ,\, 1/d_i \right ) ## and plot that as a pint on your graph.
Since each point has a ##y##-coordinate of ##\displaystyle 1/d_i ## , you should solve the equation ##\displaystyle 1/f = 1/d_o+1/d_i ## for ##\displaystyle 1/d_i ##. Comparing the resulting equation to the equation ##\displaystyle \quad y=mx+b## , your graph should have points lying roughly along a line with a slope of ##-1## having a y-intercept of about ##\displaystyle 1/f## .
Notice that the x-intercept is also ##\displaystyle 1/f## .
  • · Replies 20 ·
