Gravitational force between 2 particles
The discussion revolves around calculating the gravitational force exerted by a 1900kg solid sphere on a 1.50kg point mass at two distances: 5.01m and 2.45m. The gravitational force formula used is Fg = GMm/r^2, where G is the gravitational constant. The user attempts calculations but expresses confusion regarding the results, particularly the use of 5^2 in the equations. Clarification is sought on the application of the radius in the calculations. The thread highlights the importance of correctly applying gravitational formulas to solve physics problems.
clope023
A uniform, solid, 1900kg sphere has a radius of 5.00m. Find the gravitational force this sphere exerts on a 1.50kg point mass placed at the following distances from the center of the sphere: (a) 5.01m , and (b) 2.45m.
Fg = GMm/r^2
volume of sphere = (4/3)piR^3
density of sphere = M/volume
ratio of point mass to shere:
M/msphere = (4/3piRM^3)/(4/3piRsphere^3)
Mmass = msphere(Rmass/Rsphere)^3
G(M)(mmass)/r^2 = Gmass(msphere(rmass/rsphere)^3)/Rsphere^2
= G(mmass)(msphere)rmass/rsphere
Fg = G(1900)(1.50)(5.01)/5^2 = 3.8x10^-7
Fg = G(1900)(1.50)/5^2 = 8x10^-8
nothing, I'm not sure what I'm doing wrong, any help is greatly appreciated.
Fg = GMm/r^2
Where are the 5^2 coming from?
