How Does the Gravitational Force Equation Change with 1/r^3?
The discussion explores the gravitational force equation, emphasizing the transition from the conventional inverse-square law (F = Gm1m2/r^2) to a vector form that incorporates a 1/r^3 term. This adjustment arises when calculating the force vector between two mass points, where the distance r is defined as the Euclidean distance between their coordinates. The force vector is expressed as F = -G(m1m2/|p1 - p2|^3)(p1 - p2), which maintains the inverse-square relationship while normalizing the direction of the force. The additional r^3 factor is necessary for proper vector normalization. This approach, while unconventional, aligns with the principles of gravitational interaction in a vector context.
nearc
apologies if this has been covered elsewhere in the forums, but i was unable to find it. I've seen the usual gravitational force equation [i.e. F=gMm/r^2] with essentially r^3 in the bottom. an example of this can be seen in http://www.mathworks.com/moler/exm/chapters/orbits.pdf on pages 8 and 9.
i'm looking for any info [paper/webpages] that might explain how to use this approach, thanks
Astronomy news on Phys.org
it's a vector equation and the author (who happens to be the guy who created the first MATLAB) is not being conventional with his math symbols.
Newtons gravitational law can first be stated:
F = G \frac{m_1 m_2}{r^2}
where F is the magnitude of the force vector that runs along the line that connects m_1 and m_2. and r is the Euclidian distance between them. this is a scaler equation and is the simple inverse-square gravitational equation you see most everywhere.
now suppose that the body with mass m_1 is located at point \vec{p_1} and the body with mass m_2 is located at point \vec{p_2}. the coordinates of the points are
\vec{p_1} = ( \ x_1, \ y_1, \ z_1 \ )
\vec{p_2} = ( \ x_2, \ y_2, \ z_2 \ )
the distance between the two points \vec{p_2} and \vec{p_1} is
r = | \vec{p_1} - \vec{p_2} | = \sqrt{(x_1-x_2)^2 +(y_1-y_2)^2 +(z_1-z_2)^2 }
now, the difference vector that connects \vec{p_2} to \vec{p_1} is \vec{p_1}-\vec{p_2}, so r is just the magnitude of that difference vector.
lastly to get a force vector \vec{F} that has magnitude F, we need to create a unit vector that runs along the line that connects \vec{p_2} to \vec{p_1}. that unit vector is the difference vector \vec{p_1}-\vec{p_2} normalized by dividing by its length r=|\vec{p_1}-\vec{p_2}|. this is where the extra power in r^3 comes from.
so the force acting on the body with mass m_1 located at point \vec{p_1} by the body with mass m_2 located at point \vec{p_2} is
\vec{F} = -G \frac{m_1 m_2}{r^2} \frac{\vec{p_1}-\vec{p_2}}{|\vec{p_1}-\vec{p_2}|}
or
\vec{F} = -G \frac{m_1 m_2}{|\vec{p_1}-\vec{p_2}|^3} (\vec{p_1}-\vec{p_2})
that is a vector equation, but it is still the inverse-square law. the extra power of r in the denominator is needed to normalize the vector connecting point \vec{p_2} to point \vec{p_1}
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
