Gravitational Forces on three masses at the corners of an equilateral triangle
  • Thread starter Thread starter hasibx
    Gravitation
The discussion focuses on the gravitational forces acting on three masses positioned at the corners of an equilateral triangle. The mathematical solution presented involves the vector rule, resulting in a force expression that includes a negative component, specifically (-\hat{j}). The question raised concerns the necessity of knowing the coordinate positions of the masses to understand why the negative sign is used. It is emphasized that without a clear definition of the coordinate system, the assumption of the direction of (-\hat{j}) may lead to confusion. Clarifying the positions of the masses in relation to the x-y coordinates is essential for accurate interpretation of the results.
hasibx
Three identical masses m are kept at the vertices of equilateral triangle of side 'a'. Find the force on A due to B and C
F =\frac{Gm_{1}m_{2}}{r^2}
I solved the math using vector rule
R= \sqrt{F^2 +F^2 +2F^2cos\frac{\pi}{3}} =\sqrt{3}\frac{Gm^2}{a^2}
But the answer is showing: \sqrt{3}\frac{Gm^2}{a^2} (-\hat{j})
My question is:
Why is (-\hat{j}) added here? Why is it negative?
We would need to know the positions of the masses in terms of the coordinate system.
That's not what I asked for, but the given answer seems to be assuming that ##\hat j## is straight up the page in that diagram. If you were not told that then I do not see how you could be expected to get that answer.
@hasibx you do not seem to understand what it means to
WHERE do the points sit relative to the x-y coordinates?
