GRE 9367 Problem #38 (Summations + Limits)
  • Thread starter Thread starter moo5003
    Gre Limits
moo5003
The limit as n approaches infinity of:
The sum from i = 1 to n of:
(3/n)^3 * i^2 - (3/n)^2 * i
A) -1/6
B) 0
C) 3
D) 9/2
E) 31/6
Answer - D
So, my first idea was to split the sum into two distinct sums and then take out powers of 3/n
ie:
Limit of:
27/n^3 Sum of i^2
Limit of:
9/n^2 Sum of -i
Now the second sum is just -(n+1)n/2 thus the second term goes to -9/2 as n goes to infinity.
This is were I'm stuck any help would be appreciated. Or suggestions on approaching this problem differently.
Why do you only have sum(i^2) in the first one. Isn't it sum(i^3)? Are you sure you've stated the problem correctly? As stated, the limit diverges.
Sorry you are correct, I didnt write it out correctly. I edited the first post so it should be correct now.
The sum of i^2 from 1 to n is n(n+1)(2n+1)/6. That's one way to do it. The easy way is to recognize it as a Riemann sum for the function 27x^2-9x integrated between 0 and 1.
Thanks for the sum on i^2 seems to work out. I'm a little unclear how you recognize that the sum is infact a riemann sum integrated between 0 and 1.
I can see where the function is namely 27i^2-9i however could you explain in further detail how the interval is seen?
Split the interval [0,1] into n equal intervals. The value of x at the end of an interval is i/n. The width of a rectangle is 1/n. The height of the rectangle corresponding to f(x)=27x^2-9x is 27(i/n)^2-9(i/n). Multiply height time width and that the contribution to the area sum from each rectangle. That's your sum.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
