How to Calculate Maximum Induced EMF in a Rotating Coil Gaussmeter
  • Thread starter Thread starter tim_3491
    Calculation
To calculate the maximum induced EMF in a rotating coil gaussmeter, the formula e = ωnBA is used, where ω is the angular frequency in radians per second, n is the number of turns (400), B is the magnetic field strength (0.45 T), and A is the area of the coil (1.4 cm²). The coil rotates at 180 rpm, which needs to be converted to radians per second for the calculation. The maximum induced EMF occurs when the coil is oriented perpendicular to the magnetic field. Understanding the relationship between these variables is crucial for determining the induced EMF in the system.
tim_3491
Gaussmeter calculation
This device used a small loop of many turns rotating on an axis perpendicular to the magnetic field at fairly high speed and connected to an ac voltmeter by means of slip rings. The sensing coil for a rotating coil gaussmeter has 400 turns and an area of 1.4 cm2. The coil rotates at 180 rpm. If the magnetic field strength is 0.45 T,
find the maximum induced emf in the coil and the orientation of the coil relative to the field for which this maximum induced emf occurs.
Anyone know how to do this one? And more importantly why does it say 180rpm but also give me a value for n (400turns)
Anyone know how to do this one? And more importantly why does it say 180rpm but also give me a value for n (400turns). I don't even know how to start it
gaussmeter
the maximum value of the induced emf is given by a simple relation e=wnba, where w is the angular frequency (rpm but in rad/s units), n is the number of turns of the coil, b is tha magnetic field intensity and a is the area of the coil face.
ba represents the maximum magnetic flux through each turn of the coil, nba is the total maximum flux, and wnba is the maximum rate of change of this flux which is the maximum induced emf !
