Guidance on Engineering Minor Selection
Selecting an engineering minor should align with career goals and interests, particularly when specializing in Mechanical Engineering. The options discussed include Engineering Business, Environmental Engineering, and Sustainable Energy. It's crucial to consider how each minor complements the chosen majors of Solid Mechanics and Machine Design, and Energy and Environment. Ultimately, personal aspirations and future job prospects should guide the decision-making process. Making informed choices rather than relying on external opinions is essential for success.
rahmanz4
Choose from the following: Engineering Business, Environmental Engineering and Sustainable Energy.
I will be specializing in the 2 majors of Mechanical Engineering - (i) Solid Mechanics and Machine Design and (ii) Energy and Environment. This minor will hold side by side with the 2 majors.
asking the internet to make life decisions for you is a recipe for disaster.
what do you want to do when you graduate?
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
