Hard Rotational Kinetic energy question (Flywheel)
The discussion revolves around calculating the rotational kinetic energy of a flywheel subjected to a torque of 5 Nm. The user initially miscalculated the moment of inertia by incorrectly incorporating gravitational acceleration, leading to confusion about units. After clarification, the correct formula for moment of inertia is confirmed as Ig = 1/2 * m * r^2, and the radius is correctly identified as half the diameter. The user successfully derives the angular acceleration and angular velocity, ultimately calculating the rotational kinetic energy as 56010.5 J. The conversation emphasizes the importance of using mass instead of weight in these calculations.
orangeincup
A motor imposes 5 Nm on a shaft of a 100kg flywheel which is 80cm(diameter)
What is the rotational kinetic energy after 10 mins? assuming the flywheel was at rest and the mass moment of inertia of the shaft is negligble.
Ig=1/2 * mr^2
RKE=1/2*Ig*ω^2
T=Ig*Ac
ω=ω0+ Ac*t
Can someone look at this and tell me what I should change? I have no idea if it is right or not.
Solving for moment of inertia: Ig= 1/2 * m*r^2, Ig=1/2*(100kg*9.81m/s^2)*(.8m/2)^2
Ig=78.4(not sure units)
Solving for acceleration:
T=Ig*Ac
5/78.4=Ac
0.063=Ac (not sure units)
Solving for ω:
ω=ω0+Ac*t
ω=0+0.063*(10minutes*60)
ω=37.80 rad/s
Solving for RKE:
RKE=1/2*Ig*ω^2
RKE=56010.5 J
Why did you multiply by g? You want the mass, not the weight.
Other than that, your method looks OK.
Likes 1 person
Opps. Thank you.
Make sure the information given in the problem matches the information required for your formula.
Is the radius of the flywheel the same as its diameter?
If you are not sure of the units of your answer, calculate them according to the formula you are using.
If inertia = 1/2*m*r^2, then the units will be kg (mass) * m^2 (radius^2), or kg-m^2
orangeincup said:
Opps. Thank you.
Should be 'Oops'. 'Opps' rhymes with 'tops', while 'oops' rhymes with 'loops'.
Likes 1 person
It was divided by 2.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
