Harmonic Oscillator Homework: Issues with d)
The problem involves a harmonic oscillator described by the equation x=(12.4cm)cos( (34.4 rad /s)t+ π/5 ). The original poster seeks assistance specifically with part (d) of the question, which asks when the object is at its equilibrium position, while also requesting confirmation on the correctness of their previous answers for parts (a), (b), and (c).
  • Exploratory, Assumption checking
  • The original poster attempts to determine when the object is at its equilibrium position by setting the cosine function to zero. They express uncertainty about their algebra skills and the validity of their approach.
  • Some participants suggest considering the angles for which the cosine function equals zero, indicating that there are multiple solutions.
  • Others explore the implications of the periodic nature of the cosine function in relation to the problem.
Participants have provided guidance on how to approach part (d) by focusing on the conditions under which the cosine function equals zero. There is an ongoing exploration of the implications of these conditions, including the periodicity of the solutions.
The original poster expresses concern about their algebra skills and the potential for missing information in their calculations. There is also a mention of the period of the oscillation, which is relevant to understanding the timing of the equilibrium position.
alex91alex91alex
I am having issues with d) and would like to know if I did the a, b, and c correctly. I have tried to look online for explanation but with no success.
A harmonic oscillator executes motion according to the equation x=(12.4cm)cos( (34.4 rad /s)t+ π/5 ) .
a) Determine the amplitude of the oscillation.
b) Determine the maximum velocity of the oscillation.
c) Determine the period of the oscillation.
d) Determine when the object is at its equilibrium position.
max v=Aw
T=1/f
Amplitude would just be 12.4cm, we can take it straight out from the equation.
max v=Aw=0.124m*34.4rad/s=4.27m/s
Here we know that 2π rad is one turn so 34.4 rad is 5.48 turns.
So we have 5.48 turns per second.
T=1/f=1/5.48=0.183secs
I know that the object is in equilibrium when x=0, so
0=(12.4cm)cos( (34.4 rad /s)t+ π/5 )
I may be missing some algebra skills, but I even try to compute it online and it wields no solution. What am I doing wrong?
Your work on parts (a) through (c) looks fine.
For part (d), consider what the argument of the cosine function needs to be for the cosine to be zero. (Hint: there are many such angles)
So cos( (34.4 rad /s)t+ π/5 ) need to equal 0?
(34.4rad/s)t+π/5 has to be equal to π/2 or 3π/2?
That is going to wield t= 0.02739s and 0.1187s, does not feel right though because a period takes 0.183secs.
Yes.
In fact, the cosine will be zero every time its argument is equivalent to π/2 or 3π/2. You should be able to write it as a function of n, where n = 0,1,2,... Or you can solve for the first instance (n = 0 so that the argument is π/2) and then it will happen every half period after that.
  • · Replies 21 ·
