Having trouble with Integration by Parts
The discussion revolves around the integration of the function arctan(√x) using integration by parts. The initial approach involves setting u = arctan(√x) and dv = dx, leading to a complex integral that seems to circle back to the original function. A second case simplifies the integrand, allowing for a clearer path to the solution, ultimately revealing that the integral can be expressed in terms of arctan(√x) and other simpler integrals. The final steps confirm that the integration yields a result involving arctan(√x) and a constant, demonstrating the importance of recognizing patterns in integration. The participants emphasize the value of breaking down complex expressions to find solutions.
relinquished™
I'm real stuck with this problem of mine in The Calculus 7 by Leithold
<br /> \int arctan \sqrt{x} dx<br />
Since there is no elementary formula for integration of an inverse trigo function, we cannot manipulate the integrand in such a way as to integrate easily with one step of Integration by parts.(please verify)
So first, If we let u = arctan \sqrt{x} and
dv = dx
then
du = \frac{dx}{2 \sqrt{x} (x+1)} and
v=x
then we have
<br /> \int arctan \sqrt{x} dx = xarctan \sqrt{x} - \int \frac{xdx}{2 \sqrt{x} (x+1)}<br />
Now, Case 1, without simplifying \frac{x}{\sqrt {x}}
let db = \frac{1}{2 \sqrt{x} (x+1)}dx
and a = x.
Then da = dx
and b = arctan \sqrt{x}
so
<br /> \int arctan \sqrt{x} dx = xarctan \sqrt{x} - xarctan \sqrt{x} + \int arctan \sqrt{x} dx
which of course will lead us nowhere but 0=0
Now, Case 2 - If we simplify \frac{x}{\sqrt {x}} = \sqrt{x}
let a= \sqrt{x} and db = \frac{dx}{1+x},
then da = \frac{dx}{2 \sqrt{x}} and b = ln (x+1)
so
<br /> \int arctan \sqrt{x} dx = xarctan \sqrt{x} - \frac{1}{2} ( \sqrt{x}ln (x+1) - \int \frac{ln |1+x| dx}{2 \sqrt{x}})
and if we do Integration by parts again, we will just get an infinite sequence of \sqrt{x}ln (x+1) (please verify)
I'm really open to suggestions ^_^`
javascript:;
From there... add 1 and -1 to your numerator, and disect the expression into two... hope you figure out the next steps. (in your integral of udv)
0.0 hey... why didn't I think of that?
\int arctan \sqrt{x} dx = xarctan \sqrt{x} - \int \frac{x + 1 - 1}{2 \sqrt{x} (x+1)}dx
\int arctan \sqrt{x} dx = xarctan \sqrt{x} - \int ( \frac{(x + 1)}{2 \sqrt{x} (x+1)} - \frac{1}{2 \sqrt{x} (x+1)}) dx
\int arctan \sqrt{x} dx = xarctan \sqrt{x} - \int ( \frac{1}{2 \sqrt{x}} - \frac{1}{2 \sqrt{x} (x+1)}) dx
\int arctan \sqrt{x} dx = xarctan \sqrt{x} - \int \frac{dx}{2 \sqrt{x}} + \int \frac{dx}{2 \sqrt{x} (x+1)}
\int arctan \sqrt{x} dx = xarctan \sqrt{x} - \sqrt{x} + \int \frac{dx}{2 \sqrt{x} (x+1)})
let u^2 = x, then u = \sqrt{x}, since du = \frac{1}{2 \sqrt{x}}it can be integrated directly and it yields arctan...
so
\int arctan \sqrt{x} dx = xarctan \sqrt{x} - \sqrt{x} + \int \frac{du}{(u^2+1)}
\int arctan \sqrt{x} dx = xarctan \sqrt{x} - \sqrt{x} + arctan \sqrt{x} + C
Is this correct? ^_^;;
Man... I really don't like it when the answer is just right in your face and slaps you XD. Gotta remember the +a -a concept ^_^;;; Thanx btw Irony of Truth
now that's correct.
