Exploring the Inevitable Heat Death of the Universe
In summary: If the universe progresses as we currently think it should, then eventually everything will become cold, lifeless, and immobile.2. This "heat death" would then be a perpetual state as matter/energy interactions occur in very small and almost unnoticeable ways.3. However, this is only assuming current models. If our current understanding are wrong, then density of the universe could exceed critical density, resulting in a "big crunch."In summary, the current theory suggests that the universe will end in heat death, where everything becomes cold and lifeless. However, this is only assuming current models are correct, and there is a possibility that dark energy is not yet well enough understood to rule out the possibility of
Delong
400
I heard that eventually the universe will end in heat death where everything becomes cold and lifeless and immotile. Is this true and is it inescapable? What can we perhaps do about it?
Space news on Phys.org
That is the current theory and it is widely supported by most scientists and by the evidence. There IS a theory (maybe more than one?) that suggests that dark energy is not yet well enough understood (hey, there's an understatement for you!) to rule out the possibility that the currently accelerating expansion will eventually reverse and there will be a big crunch, but I don't know how seriously, if at all, such theories are taken by mainstream science.
Presuming the universe progresses as we currently think it should (i.e. no big crunch, no false vacuum though neither of those seem particularly survivable) it doesn't look like there's anything we can do to avoid the heat death. Hypothetically a society may survive longer by constructing habitats with ultra-efficient recycling that take their energy from black hole Hawking radiation but inevitably entropy will win.
If DE (Dark Energy) is not sufficiently strong enough to overcome gravity at some point in the future, then eventually all last vestiges of matter/energy will be spread over incredibly vast differences and essentially will be so diffuse as to enter "heat death". This "heat death" would then be a perpetual state as matter/energy interactions occur in very small and almost unnoticeable ways.
However this is only assuming current models. As phinds has pointed out in his previous post there are theories that refute our current understanding of DE and its continued role on a large scale level on the Universes evolution. If our current understanding are wrong and density of the Universe exceeds critical density then essentially this will result in a "Big Crunch" - however as stated this is speculative and against current comsmo model consensus.
Asking what we can "perhaps do about it" is not really a valid question. On a planetary level we have little influence - so to extend this to solar, galactic and universal levels accomplishes nothing. To be able to do anything about it we would need to be able to fundamentally alter laws of physics in currently incomprehensible ways! Essentially we would need a "magic technology X" which is neither plausible not probable and some would argue is impossible.
I must admit I love the optimism though! :smile:
Don't forget about the Big Rip! While this would require a form of phantom energy with [itex]p < -\rho[/itex] which is quantum mechanically unstable and leads to a host of other pathologies, current data does seem to favor it.
Cosmo Novice said:
If DE (Dark Energy) is not sufficiently strong to overcome the acceleration forces of expansion,
You've contradicted yourself with the statement above. DE is not something that is going to overcome the acceleration, DE CAUSES the acceleration. The only hope of the "big crunch" theories is that DE isn't strong enough to CONTINUE the accelerated expansion AND something else happens to reverse the expansion (I THINK, but am not sure, that I have read that at this point, even if DE went away, gravity would not longer be able to reverse the expansion, so the "big crunch" is going to require a fundamental change in SOMETHING.
I'm pretty sure that depends on the global geometry of the universe. If the universe is closed, and all the dark energy simply went away, then we would be left with a closed matter dominated universe and a big crunch would be inevitable.
Thankyou, I wrote this at work very quickly and when I re-read it back just now it makes absolutlety no sense! I have edited accordingly and thankyou for pointing that out.
Could be I have a fundamental misunderstanding, but if I have it right, your logic is circular. Because spacetime is affected by gravity, it IS gravity that determines whether or not the U is open or closed (or flat) and if that's the case then your argument is circular. I'm new to all this and as I said, I recognize that I may have that wrong.
He just pointed out a physical scenario under which we might get a big crunch without any sort of fundamental change in gravity. It does require that the dark energy changes its behavior dramatically in the future, but other than that no change is necessary.
That said, the expectation right now is a universe which expands forever, and in that situation a heat death is inevitable.
No one knows for sure yet; so all of this is in the speculative nature.
So here is some speculation!
Let’s consider “Heat Death” as regards to a "Big Bounce" scenario for an "Oscillating" model of the Universe. Which starts off hot, then cools; then gets hot again, and cools again...and on and on...
Whenever it is mentioned that Gravity halts the expansion of the universe, this is referring to the fact the "Dark Energy”, which causes Space-time expansion, becomes diluted, and loses its grip. When the expanding "Dark Energy" becomes diluted, and loses its grip, it finally becomes weak enough to allow the matter and the Gravitational Energy to become strong. Eventually "Gravity" will be able to clump matter together in the form of galaxies. This "Gravity" will continue to pull all matter into a single clump and form one big blob of mass.
With Gravity acting alone without the grips of the expanding “Dark Energy”, this could conceivably continue to condense all the matter in the universe forming a Universal "Black Hole" or new Epoch, which would get so hot and dense it would create a new bang, and begin to expand once again. Once, all matter is condensed and forms one big blob of mass; this restarts the process and the Dark Energy wins over Inertial Mass Gravity; and starts the whole process over again.
Once again, this is total speculation, and is meant for discussion. I am not sure if I agree with this scenario; however this is possible.
Just bear in mind that for this to happen, the dark energy would have to radically change its behavior. The most likely situation is that it will continue acting as it has up to now, which means continued acceleration indefinitely. This, in turn, means a heat death.
Based on your post, you obviously accept that the universe ends up in a "Heat Death" this is perfectly ok.
But the original post (OP) asked the question
Delong said:
... heat death ... Is this true and is it inescapable? What can we perhaps do about it?
So the answer is that a "Big Bounce" or an "Oscillatory Universe" model allows us to escape the inescapable "Heat Death"
This is speculation only based on the (OP)'s question:
However, the "Dark Energy" would not have to, as you put it, radically change its behavior. The "Dark Energy" is doing what it is suppose to do, expand Space-time in the presence of matter. And Inertial Mass Gravity is doing what it is suppose to do. Cause Inertial Matter/Mass to clump together.
What this model would suggest is that there is another Force and Energy out there that counter acts the "Dark Energy" over long distances. I propose that this energy is called the "Heat Radiation Gravitation" energy of space-time. The "Heat Radiation Gravitation" energy would cause the expanding "Dark Energy" to become diluted, and loses its grip, and finally becomes weak over great distances.
Once again, this is total speculation, however, there is some evidence for the above, and is meant for discussion.
Darn...
that really sucks.
Delong said:
Darn...
that really sucks.
What really sucks?
Please reread the forum's rules (which you have agreed to when you joined) on overly speculative posts.
Sup_Principia said:
What really sucks?
That heat death is most probably inevitable.
If it makes you feel better, it probably won't happen before you die of old age.
However, here is some evidence for a peer reviewed article on the subject. And this takes the "Big Bounce" model out of complete speculation; and therefore no forum rule is violated. I have read all of the rules for posting on this forum, and do completely comply.
http://www.newscientist.com/article...nce-cosmos-makes-inflation-a-sure-thing.html"
It does a little...still it's kind of sad sometimes. I'm so glad I'm religious hahahaha...
Yes, but again, that requires a model radically different than the simplest model that fits observation.
This is a model that is radically different from the simplest one that fits observation, and involves dark energy that behaves radically different in the future than it has up to now.
Oh, and "heat radiation gravitation" makes no sense.
Why does that suck? If the dark energy is truly a cosmological constant, then the universe will approach a small but non-zero temperature in the far future. This non-zero temperature means that there will be quantum fluctuations that will produce new regions of space-time periodically within our own. A heat death universe is not the end except in the sense that it is the end of our universe. A recollapse scenario would just bring about the end of our universe more rapidly.
Sup_Principia said:
I knew that "You" personally were coming after me! I know your type! You were watching everyone of my post, just waiting for an opportunity to throw some kind of a rock. That is why I continued to refer back to the original post (OP)'s question. Which could not be answered without speculation.
I don't see any correlation between the "Heat Radiation Gravitation" material in your #14 and the New Scientist article you linked to. The New Scientist is not a peer-reviewed journal. The OP can be discussed without violating PF's rules on overly speculative posts.
-Ben
-Ben
You are right the article does not mention the term "Heat Radiation Gravitation" The article mentions "Superinflation", which in my opinion gives a better interpretion of the term "Superinflation."
You are correct the New Scientist is not a peer-reviewed journal, but in the article they reference peer reviewed papers:
Article: http://www.newscientist.com/article...nce-cosmos-makes-inflation-a-sure-thing.html"
Physical Review D - http://prd.aps.org/abstract/PRD/v77/i6/e063516" Physics Letters B - http://www.sciencedirect.com/science/article/pii/S0370269310011585"
Chalnoth, can you provide any supporting material for your speculative ideas?
The article has nothing to do with the speculative material in your #14. Please calm down.
Since you are making it sound like you understand the "SuperInflation" concept as described in the article. Then explain what you think the article means by "SuperInflation" in regards to the "Big Bounce" theory; which would act in contradiction to a "Heat Death" model of the universe; which is based on the original post (OP)'s question??
Answering this question is what is called, engaging in physics!
Sup_Principia said:
This appears highly speculative.
Only in the sense of proposing that the dark energy truly is a cosmological constant. But then that's not so much speculative as it is the simplest explanation that fits the data. Anyway, here's a paper that went into this in a fair amount of detail:
http://arxiv.org/abs/hep-th/0410270
Chalnoth, you mention that the dark energy truly is a cosmological constant. The speed of light in a vacuum is a cosmological constant. Are you supposing that the dark energy is truly is a cosmological constant, like the speed of light in a vacuum?
Are you stating that the Dark Energy has the same value throughout the universe? If this is true where is this found in litererature??
And what is the math that describes this dark energy cosmological constant?
  • #31
This is equivocation. The cosmological constant is a very specific parameter in General Relativity. The speed of light is a different constant with very different implications.
I'm not so sure going into a discussion of the mathematics involved here would be that good for this thread. But suffice it to say that the fact that the cosmological constant is a constant is precisely what makes it cause the acceleration of the expansion of the universe.
  • #32
With regards to the OP "what can we do about it":
I think the unltimate fate of the U, whether Big Rip, Oscilatory or a heat death, is completely beyond our realm of influence. It is like asking what an Ant can do to stop the Earth moving round the Sun - a crude analogy but meant to emphasize the totally limited influence we have on an entire Universes evolutionary path.
  • #33
I would also like to add that this analogy is expected to hold no matter what level of technology our species eventually reaches.
  • #34
In order to remove "personal heat", this thread has been edited. This thread should stay on topic, so any concerns about the editing should be sent to me (or any other Mentor) by PM.
  • #35
Thanks Chalnoth - I should have emphasized that I would expect the analogy to hold no matter what level of technology we could potentially attain.
<h2>1. What is the heat death of the universe?</h2><p>The heat death of the universe, also known as the Big Freeze, is a theoretical concept in which the universe reaches a state of maximum entropy, where all energy is evenly distributed and no further work can be done. This would result in the end of all life and the inability for any new stars or galaxies to form.</p><h2>2. Is the heat death of the universe a proven concept?</h2><p>No, the heat death of the universe is a theoretical concept based on the second law of thermodynamics. While there is strong evidence to support this idea, it is not yet proven and is still a subject of ongoing scientific research and debate.</p><h2>3. When is the heat death of the universe expected to occur?</h2><p>Based on current theories and calculations, the heat death of the universe is estimated to occur in about 10^100 years, which is an incredibly long time in the future. However, it is important to note that this is just an estimation and it could happen sooner or later depending on various factors.</p><h2>4. Will humans still exist when the heat death of the universe happens?</h2><p>It is highly unlikely that humans or any other forms of life will exist when the heat death of the universe occurs. As the universe continues to expand and cool, it will become increasingly inhospitable for life to exist. However, it is impossible to predict the exact timeline of human existence and the heat death of the universe, so this is just a speculation.</p><h2>5. Is there any way to prevent the heat death of the universe?</h2><p>At this point in time, there is no known way to prevent the heat death of the universe. The second law of thermodynamics suggests that entropy will always increase, leading to the eventual heat death of the universe. However, as our understanding of the universe continues to evolve, it is possible that new theories or technologies may arise that could potentially delay or even prevent the heat death of the universe.</p>
  • Cosmology
