Why Does Temperature Remain Constant When Water Boils?
When water reaches its boiling point, the temperature remains constant despite continuous heat energy transfer. The graph of time versus temperature would show a linear increase to 100 degrees Celsius, followed by a horizontal line during the boiling phase. This horizontal line indicates that the temperature does not rise because the energy is used for the phase change from water to steam. The heat energy is absorbed to break molecular bonds rather than increase temperature. Thus, during boiling, the temperature remains stable while energy is utilized for vaporization.
physgirl
So if heat energy is transferred at a constant rate until the water reaches its boiling point temperature (in 6 min let's say)... and then heat energy is transferrred at the same rate as the water boils for the next 4 min...
would the graph of time v. temperature look like: a straight line with constant slope going from original water temperature to 100 degrees in the first 6 minutes and then a straight horizontal line b/w 6 min and 10 min?
also, if that is correct, for the last 4 minutes, is the temperature constant despite the heat energy transfer because... the energy was being spent on changing water to steam rather than increasing the temperature?
Yes and yes.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
