Heat Capacity of Snow vs Water
A 30,000 kg mass of snow at 0 degrees Celsius can contain more heat energy than 1 mL of liquid water at 100 degrees Celsius due to the concept of latent heat. Snow, being in a solid state, has a significant amount of heat energy stored as latent heat of fusion, which is released when it melts. In contrast, the heat content of the small volume of water at 100 degrees Celsius is limited by its mass. The discussion also touches on the potential for misunderstanding regarding the definition of "heat energy" and whether the inquiry is related to homework. Overall, the comparison highlights the importance of mass and state of matter in determining heat energy content.
skrewd1
Explain how it is possible for a 30,000 kg of snow at 0 deg C to contain more heat energy than 1 mL of liquid water at 100 deg C. (Assuming a pressure of one atmosphere.)
Science news on Phys.org
Is this homework? Do you know what "heat energy" is?
Didn't I just respond to this in 'College Homework'? :confused:
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
