Mathematica Heat Equation in Polar coordinates in Mathematica
The discussion revolves around solving the heat equation in polar coordinates using Mathematica, specifically for a disk with radius 'a'. The user encounters errors with the NDSolve function, particularly regarding boundary conditions and the interpretation of polar coordinates. Suggestions include ensuring that the theta variable runs from 0 to 2π and confirming that sufficient boundary conditions are provided, especially at the origin where the behavior of the solution can be problematic. The conversation also touches on the possibility of using DSolve for symbolic solutions instead of NDSolve for numerical ones. Overall, clarity on boundary conditions and coordinate interpretation is crucial for resolving the issues faced.
Hop
Hi! Can someone please help?
I'm trying to solve the heat equation in polar coordinates. Forgive my way of typing it in, I'm battling to make it look right. The d for derivative should be partial, alpha is the Greek alpha symbol and theta is the Greek theta symbol.
du/dt = (alpha.alpha)[(d/dr)(du/dr)+(1/r)du/dr+(1/(r.r))(d/theta)(du/dtheta)]
This is the heat equation for a disk with radius a.
u(r,theta,0) = (a-r)cos(theta)
u(a,theta,t) = 0
In Mathematica, I used:
NDSolve[{Derivative[0,0,1][u][r,theta,t]==alpha Derivative[2,0,0][u][r,theta,t]+alpha Derivative[1,0,0][u][r,theta,t]+alpha Derivative[0,2,0][u][r,theta,t], u[r,theta,0] == (a-r)Cos[theta], u[a,theta,t]==0},u,{r,0,a},{theta,0,1},{t,0,1}]
I got an error: NDSolve: bcart
I tried replacing alpha with 2 and a with 4. Still got a problem. Is there a way of keeping the alpha's and a's? And can the radius start from 0, without problems?
Then I need to plot it in 3 dimensions. I tried: (radius starting from 1 since I had problems)
Plot3D[Evaluate[u[r,theta,t] /. First[%]],{r,1,4}, {theta,0,pi}, {t,0,1},PlotPoints -> 50]
I got an error: Plot3D: plnc (repeatedly)
General :: stop
Plot3D[InterpolatingFunction[{{1.,4.},{0.,3.14159},{0.,1.}},<>][r,theta,t],{r,1,4},{theta,0,pi},{t,0,1}, PlotPoints -> 50]
I still need to add a different boundary condition where du/dr(a,theta,t) = 0 and need to solve u(r,theta,t). Would it work the same way?
Please help! I would really appreciate it!
Thanks,
Hop
u(a,theta,t) = 0
General :: stop
Thanks,
Hop
These equations are unreadable. Please use LaTex.
\frac{\partial u}{\partial t} = \alpha^2\left(<br /> \frac{\partial^2 u}{\partial r^2} + \frac 1r \frac{\partial u}{\partial r} + \frac{1}{r^2} \frac{\partial^2 u}{\partial \theta^2}\right)
u(a,theta,t) = 0
Please use code tags for code. It prevents the parser interpreting [u] as an underline tag.
Code:
As I read it, you have \theta running between 0 and 1. Surely you want \theta between 0 and 2\pi?
NDSolve is for numerical solutions. This necessarily involves telling Mathematica what values of \alpha and a you want it to use (but in any event you can remove both of them from the problem by suitable rescalings of r and t). If you want a symbolic solution, use DSolve.
The error message indicates that you have not supplied sufficient boundary conditions. In particular, Mathematica does not know that r and \theta are to be interpreted as polar coordinates, and that therefore u(r,0,t) = u(r,2\pi,t) and that the boundary condition to be imposed at r = 0 is that \frac{\partial u}{\partial r} = 0. But the coordinate singularity at the origin may be fatal in any event: I don't think you can tell NDSolve that the value of u at the origin should not depend on \theta. (Or, if Mathematica can work all that out for itself, you only told it to look at 0 \leq \theta \leq 1 and didn't supply boundary conditions at the edges of that sector.)
