What is the relationship between heat loss and resistivity in a cable?
The relationship between heat loss and resistivity in a cable is explained through the formula R = p*l/A, where resistance (R) increases with length (l) and resistivity (p). Heat loss in a conductor is proportional to the current squared times the resistance (P = I^2R). A longer cable results in higher resistance, leading to increased heat generation. The discussion clarifies that while resistivity is important, the length of the conductor significantly impacts overall resistance and heat loss. Understanding these relationships is crucial for optimizing cable performance and safety.
dinhjeffrey
http://img710.imageshack.us/i/2631001.jpg/
#29
p=I^2R
P=IV
well, the answer is D, but i don't see why the length matters? can anyone find out the equation for this problem?
i thought it was B) cable B because it has more resistivity
The resistance of a conductor can be found using the equation,
R = p*l/A
where R = resistance, p = resistivity, l = length of conductor, and A =cross sectional area of conductor.
Length matters because the longer a resistor is, the more it can obstruct the flow of charge.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
