Heat treat 800H steel to 1600F -- any contractors that can do this?
  • Thread starter Thread starter Rob Inks
    Heat Steel
A user seeks contractors capable of preheating a 40' tall, 126" ID reactor to 1600°F for welding repairs due to cracks. They emphasize the need for a contractor experienced in large-scale pressure vessel repairs, as previous contractors lacked the capability for such a project. The discussion highlights the importance of understanding the specific welding areas and consulting with a welding engineer familiar with ASME codes. Participants suggest reaching out to various companies for guidance and potentially creating a request for quotation to attract suitable contractors. Engaging with experienced professionals could lead to valuable recommendations for managing this significant repair task.
Rob Inks
I have a 40' tall 126" ID reactor that has some weld cracks. I need to pre heat this vessel to roughly 1600 F to drive impurities out of the grain before welding and also needs to be post treated. Has anyone ever done something similar on this large of a scale? I need to find a contractor capable of such a job.
You should at least do a search for companies experienced in pressure vessel repairs.
Try some of the companies at this link:
http://www.thomasnet.com/products/pressure-vessel-repair-services-91722207-1.html
Thanks for your help. I have used contractors in the past but they are not capable of such an enormous project. I know that we can't be the first company to need to do a vessel this big. Just throwing feelers out there to see if maybe anyone had been involved in a similar project.
It's not clear where the vessel is welded. Are the cracks located such that the entire vessel needs preheating? Clearly, someone had to make this thing in the first place. Have you talked to the fabricator?
I've worked in shipyards where two large castings were welded together to form one large piece. The process was officially observed to make sure proper pre-heating of the zone to be welded was accomplished, but the whole piece did not need preheating. IIRC, the minimum preheat was about 1200 °F, which was to be confirmed by using a temperature indicating stick, such as this one:
http://www.tempil.com/products/tempilstik-original/
The welding zone of the cast pieces glowed an orange-reddish color when tested, and the heat coming from them was so intense that the person wielding the temp stick had to wear a welding glove and some extra insulation just to get close enough to check the piece.
It's also not clear what your experience is in such matters. I think you should consult with a welding engineer who has experience in the relevant ASME codes governing the construction of this device. Also, it doesn't cost anything to discuss this project with various individuals or companies. The people you talk to may not be able to handle a project this size, but that does not mean they can't steer you toward someone who might be able to manage it. You might also want to consider putting together a brief request for quotation which can be sent out for people to examine.
Likes berkeman
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
