Heating Plastic: Risks & Benefits
Heating plastic can lead to various chemical reactions, producing different substances depending on the type of plastic and the temperature used. When heated, plastics can shrink and thicken, making them suitable for art projects, but this process may also release toxic fumes. The toxicity of these fumes varies with the specific polymer and the heating temperature. For example, high-density polyethylene (HDPE), commonly found in milk bottles, can be safely heated at temperatures between 230-250°C without emitting harmful gases, as long as the temperature does not exceed this range. It is crucial to avoid higher temperatures to prevent decomposition or burning. When using colored acrylics on plastics before heating, the potential for toxic emissions may increase, depending on the materials involved. Overall, careful selection of plastics and monitoring of heating conditions is essential for safe crafting.
Eureka99
Hi everybody!
I was wondering, what substances do form when plastic is heated? I found on the internet that if plastic is heated in the oven (not microwave) at 325°C, it shrinks and become more thick, and it can be used for art work. I tried to search about it, but I found different opinions about it and I don't know the scientific answer. Does it liberate toxic fumes? If yes, does it do it at what temperature? What if I color it with acrylic colors before putting it in the oven, is it even worse?
Chemistry news on Phys.org
There is no single answer, as there is no single "plastic". Decomposition products depend on the identity of the polymer heated, they can be relatively harmless or highly toxic. It can also depend on the temperature of heating.
In this case I'll try to reverse the question, do you know a specific type that can be heated without toxic fumes? For example, the plastic of CDs is ok?
I often recycle HDPE for mechanical parts:
https://en.wikipedia.org/wiki/High-density_polyethylene
My main source of HDPE are milk bottles. I shred them using an old blender, then heat them up in the oven at 230-250°C until they are soft. No obnoxious gasses are emitted, but make sure you don't go higher in temperature or it may start decomposing or burning. Then I put the paste into a mould (usually made of wood), apply pressure with a few clamps and let it cool off. Once cold, it is a very hard material, easily machinable.
Likes Eureka99
Interesting... I'll try to search this material. Thank you both!
