Height Question: Projectile launched from a table
4 replies · 2K views
fandomgeek_394
A toy car rolls off of a table at an initial angle of 0 degrees and an initial velocity of 2.81 m/sec. The ball hits the floor 1.55 m (horizontally) from the edge of this table. How tall is the table?
So far I have:
Vo=(2.81 m/sec) * cos(0 degrees)=2.81 m/sec
Delta x= volt + one half at^2
1.55m=(2.81 m/sec) times t plus one half times (0) times t^2
t=1.55 m/2.81 m/sec=0.55 sec
Vo=(2.81 m/sec) times sin(0 degrees)=0 m/sec
Delta x=volt plus one half at ^2
Delta x= (0 m/sec) times (0.55) plus one half times (-9.8 m/sec) times (0.55 sec)^2=
The result I ended up getting was -1.48225 when I was done; I feel I know I must have made a mistake at some point, as the answer shouldn't have turned up negative. Someone I asked briefly on another site came up with the answer 1.488m for the problem; I'm just not quite sure what I got off. Could someone help me figure this one out please? I feel I'm close, but off somewhat. Thanks for the help & the patience, guys.
Really do want to learn, and whatever help you can give me in making sure I get this problem right would be very appreciated. :)
The formula you used for the vertical motion gives you the displacement at time t. You took up as positive, making g negative. In falling to the floor, would you expect the displacement to be positive or negative?
Negative? I feel kind of ridiculous right now, but I still don't quite understand... Do you think you could tell me what lines in my data are off and what exactly in them I need to change? I think that would help me.
Was it the -9.8 in the problem that I got wrong? I just noticed that when I make that positive instead of negative, I get the positive answer.
You have to decide whether to make up positive or down positive. It does not matter so long as you are consistent. If up is positive then both the gravitational acceleration and the displacement are negative.
