Understanding Heisenberg's Principle: x and p instead of delta x and p
bubblewrap
I don't get how you can use x and p instead of delta x and p in Heisenberg's principle.
Also why is it just h bar? Isn't it supposed to be h bar/2?
Problem 2-iv
delta x* delta p >= h bar/2
I tried to deal with this problem but I couldn't find a way, when I looked at the solution it use the Heisenberg's principle without the deltas, I can't understand how this could be done
There's quite a few versions of Heisenberg's Uncertainty Principle. ##\Delta x \Delta p \geq h \ \text{or}\ \geq \hbar \ \text{or}\ \geq \frac{\hbar}{2} ## are the main 3 that I'm aware of, at least for position momentum uncertainty. The last reported (most accurate) that I remember was hbar over 2, but they may use a different version, depending on how old the documents are.
I also don't see where you're talking about. I just skimmed through the solutions, but everywhere that I noticed them speaking of uncertainty they either used ##\delta x \ \text{&}\ \delta p \ \text{or} \ \Delta x \ \text{&}\ \Delta p ##
Which problem are you referring to?
Edit** Somehow I missed 2.iv -.-
They're not talking about uncertainty. They're talking about the total energy of the ground state. The ground state should never be lower than 1 quantum.
So I believe that the measured values of x and p in the ground state should be of the order of the uncertainty principle. There may be more to the story, if so, someone else would have to jump in and inform us. I'm not a huge quantum guy.
Likes bubblewrap
What's 1 quantum? is it the Planck constant?
Basically, yea. It's the increment that your energy scale progresses by.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
