Help Building Rube Goldberg Machine
  • Thread starter Thread starter bobm866
    Building Machine
The discussion focuses on building a Rube Goldberg machine that incorporates specific elements, including an analogue multimeter to measure water in a pail of ice cream. Key requirements include starting with a digital camera's record button, achieving a horizontal flight of at least 30 inches, and integrating features like a roller coaster effect, elastic potential energy, and various energy forms such as heat and light. The machine must also include two electric motors, a pulley system, and a vertical elevation change of 30 inches, with a total of 20 steps allowed. Suggestions for inspiration include referencing the classic board game "Mouse Trap." The user seeks guidance on how to effectively design and construct the machine within the specified dimensions.
bobm866
Hi i need help making my rube goldberg machine. It needs to use an Analogue Multimeter to determine how much water is in a 5 quart pail of ice cream (any amount of water)
The things it needs to have in it is:
1. Needs to start by hitting record button on Digital Camera
2. 1 thing to fly 30 inches or more horizontally
3. needs to act like a roller coaster
4. Use Elastlic Ponetial Engery
5. Uses 2 Electric Motors
6. 1 heat engery with heat source
7. 1 light engery
8. 1 Magnet force
9. 1 pulley system
10. 1 30 inch upward vertical elevation change
Need 8 more steps
PLEASE HELP
Can you go over or under or are you limited to 18 steps no more and no less?
It can be 20 steps no more than twenty any suggestions to how i can build this machine the dimensions are 30 inches wide, 36 inches tall and 40 inches long
Thanks
Yeah. Take a look at the old board game "Mouse Trap."
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
