Help drawing a FBD for the question
  • Thread starter Thread starter PhysicslyDumb
    Drawing Fbd
To analyze the tension in the ropes held by a person with a mass of 70 kg at an angle of 85 degrees, a free body diagram (FBD) is essential. The FBD should represent the points where the person's hands meet the rings and where the ropes attach to the ceiling. These points will help visualize the forces acting on the person, including tension and weight. Understanding these forces allows for the calculation of tension in each rope. Properly constructing the FBD is crucial for solving the problem effectively.
PhysicslyDumb
A person is holding onto 2 separate rings and each at angle is 85 degrees. find the tension in each rope. The mass of the person is 70kg. so we know the mass of the person, and the angle of ropes, i should be able to figure it out by looking at a FBD but i don't know how the FBD would look. i just need to know what points should be taken as the square (or the dot) in the FBD, the areas where his hands meet the rings or the areas where the rope attaches to the roof
thanks, that helped a lot
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
