Calculating m2: Spheres Collision Equation | Homework Help"
  • Thread starter Thread starter rayven18
    Homework
The discussion centers on calculating the mass of a second sphere (m2) involved in a collision with a first sphere (m1) using the conservation of momentum. The initial conditions include m1 at 0.15 kg and moving at 4 m/s, while m2 is initially unknown and moving at 2 m/s. After the collision, m1 moves at 12 m/s and m2 at 10 m/s. The user initially calculated m2 as 0.04 kg but later corrected the equation to find m2 as 0.2 kg after consulting their teacher. The topic concluded with the correct value for m2 confirmed.
rayven18
Two spheres S1 and S2 are moving towards each other. Let's say that the balls are the "O" letter
O--> <--O Where m1=0.15kg and u1=4m/s and m2=; and u2=2m/s. After the hit each other they will go like this
<--O O--> Where m1=0.15kg u1'=12m/s and m2=; u2'=10m/s
Find the m2
I did the following and i think it is correct.
m1*u1-u2=m1*u1'+u2'*v (v is the value m2 we are searching for)
0.15*4-2=-0.15*12+10*v
0.60-2=-1.8+10*v
0.4=10*v
10 10
v=0,04kg
Is this correct?
Missing the m2 just before the equal sign.
Each term in the momentum equation must be an m*v or m*u.
Easier to see that if you use m instead of v for mass.
Yes i know. My bad. I asked my teacher and it should be like that 0.60+1.8=2+10*v and then do 2.4/12 and we get 0.2. Thanks for the reply though. TOPIC CLOSED
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
