Help Identifying a Component (TO-220)
  • Thread starter Thread starter teroenza
    Component
The unidentified component in question is a power N-MOSFET, specifically the "21N06" model, which is rated for 21 Amps and 60V. It is housed in a TO-220 package, with the markings "PHP 21N0GLT PHm0501E2." The component was manufactured by Philips Semiconductor, now known as NXP, and was discontinued in 2010. Although a datasheet is not available on their site, some information can be found on external resources. This identification allows for further experimentation with the pump laser diodes.
teroenza
TL;DR Summary
Hoping to get help identifying a mystery 3-terminal TO-220 component that was connected to some pump laser diodes.
I've come across an array of pump laser diodes (IPG brand, PLD-6-4) wired in series with a 3-terminal component I can't identity. I suspect it is a voltage or current regulator, but can't seem to Google-up any info on it. Markings are "PHP 21N0GLT PHm0501E2".
TO-220 package, red and black wires connected across the diode series, purple wire (half the diameter of the other two) went elsewhere and I don't know what it connected to.
Can anyone help me identify this?
That is a power N-MOSFET, search for "21N06"
Likes berkeman
Thank you!
Likes DaveE and berkeman
BTW, For MOSFETS, there is a rough estimation of the parameters in the P/N:
in "21N06", "21..." = 21 Amps, "...N..." = N-Channel, "...06" = 60V.
The letters before this are usually the manufacturer, the letters at the end are the package type.
Likes berkeman, Averagesupernova and teroenza
Thanks everyone. That should be sufficient for me to try playing with the diodes.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
