Help me for calculate a Hydraulic force
  • Thread starter Thread starter doy555
    Force Hydraulic
To calculate the hydraulic force acting on a plate using four cylinders, knowing the diameter of the cylinders is essential, but additional information is needed. Specifically, the total load on the plate and how that load is distributed are crucial for determining how much force each cylinder will carry. If the load is evenly distributed, each cylinder will support a quarter of the total load. Additionally, understanding whether the hydraulic ram is pushing or pulling will affect the calculations, as it determines the pressure on the bore side of the ram. Ultimately, knowing the hydraulic pressure and the cylinder's cross-sectional area allows for the calculation of the force exerted by the hydraulic system.
doy555
If I know only the diameter of the hydraulic cylinder that is 54 cm (4 cylinder, each cornner), how can i know the foce that act on the plate work. Do i need to know more any value ?
sorry for poor english.
really need help My boss want to know How much force acting on the plate. (Hot Press Lamination)
Hello,
I take it you want to know the force carried by each hydraulic cylinder?
You have provided very little information to enable adequate interpretation of your problem. I do not know what the actual application is. However:
If for example you have a rectangular plate which uses four cylinders (one in each corner) and you know the load that is to be carried by the plate, then the problem is very simple, provided that the load evenly distributed on the plate then each cylinder will carry 1/4 of the total load applied to the plate. It's simply like a table with 4 legs; the legs will carry 1/4 of the load - provided the load is evenly distributed.
To ensure that that hydraulic rams can withstand such a loading, you will need to know if the if the ram is pushing or pulling, or both at separate times in the operation of the machine.
If for example the ram is extending, then the pressure will be on bore side of the ram. Given this, you can easilly detertmine the bore diamter of the ram (load carrying surface area). A ram will always be rated as to its working and maximum pressures. Knowing the force applied to the ram and the surface area of the bore, you can work out the pressure in the ram - Pressure = Force/Area.
This is a very basic problem that i have described, because i do not know the actual extent of your set up and what the machine actually consists of.
This should get you going though.
I would suggest that in future you provide a full explanation of your problem, and make an attempt at the solution. If you are an mechanical engineer, then calculating what i have just described should be second nature to you?!
If you know the hydraulic pressure in kg/sq.cm or N/sq.cm, then you can calculate the force by multiplying this pressure to inside c/s area of hydraulic cylinder.
Tom
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
