Help need for piezoelectric analysis using ansys
The discussion revolves around challenges faced in conducting piezoelectric analysis for an active vibration control project using ANSYS. The user is specifically struggling with the application of voltage and stimulation aspects of the analysis. Despite checking the manuals, they have not found the necessary guidance and are seeking help urgently. Other participants suggest that the manuals should be available if the software was installed correctly and recommend accessing the ANSYS portal for additional resources. The conversation emphasizes the importance of using the correct version and accessing official documentation for effective troubleshooting.
sonu_rohith
Hi,i'm working on project called active vibration control using piezoelectric patches through ANSYS.
But I'm finding difficulties in piezoelectric analysis(application of voltage and stimulation part).
Hoping someone would have solved it ,please guide me its very urgent.
thanking you
Have you checked the manual? I haven't personally ran any of these analyses, but I know for sure that examples do exist in the manual.
Sir,i have gone through the manuals but its not there? I'm finding difficult to solve it ,can u guide me if ur confident about this analysis
I know for a fact that there is an entire chapter about piezoelectric analyses. What version are you using?
Sir, I'm using ANSYS 10 for the analysis.if u find the piezoelectric analysis manual online can u please send me the link.So that i will be benefited,
thank u.
You should have the manuals if the program was installed properly. I doubt you'll find the files online anywhere. Log into the ANSYS portal using your customer/user ID to download any files that you need for ANSYS.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
