Electric Charge and Force Calculation Help
  • Thread starter Thread starter Farside
    Electric
To solve the first problem, use Coulomb's law, which states that the force between two charges is given by F_E = (Q1 * Q2) / (4πε₀r²). For the charges of +2 x 10^-6 C and -3 x 10^-6 C separated by 20 cm, calculate the force and determine its direction based on the nature of the charges. For the second problem, apply Ohm's law, V = IR, to find the resistance of the heating element in the coffeepot, given a voltage of 120 V and a current of 0.6 A. Both calculations involve fundamental principles of electric charge and force, ensuring a clear understanding of the concepts. Understanding these laws is essential for solving similar physics problems effectively.
Farside
I missed the material for these couple of problems. If someone could help explain how to solve them I would much appreciate it. :cool:
1.) A charge of +2 x 10^-6 C is 20cm from a charge of -3 x 10^-6 C. Find the magnitude and direction of the force on each charge.
2.) A 120-V electric coffeepot draws a current of 0.6 A. What is the resistance of its heating element?
Look up Coulomb's law.
Look up Ohm's law.
F_E = \frac{Q_1Q_2}{4\pi\epsilon_0r^2}
V = IR
Also Newtons Third Law should help you determine the force on EACH charge to your first question.
