Help on motion and pressure needed
  • Thread starter Thread starter jhaywood
    Motion Pressure
The discussion revolves around solving two physics problems involving motion and pressure. For the first problem, a train accelerates to 153 km/h over 2.29 km, and participants suggest using kinematic equations to find acceleration and time, while also discussing how to calculate deceleration when brakes are applied. The second problem involves a cylindrical tank with a capacity of 51,980 liters, filled to 72% with a liquid of density 1063 kg/m³, prompting discussions on calculating pressure at the tank's base using the formula P = pgh. Various methods and formulas are proposed to approach both problems, emphasizing the importance of showing work for clarity. Overall, the thread highlights collaborative problem-solving in physics.
jhaywood
1. A train accelerates from rest at a constant rate and reaches a velocity of 153 kmh in a distance of 2.29 km. Calculate the acceleration and time taken.
If the breaks are then applied and produce a constant deceleration bringing the train to rest in a time of 140s, calculate the rate of deceleration
2. A vertical cylindrical chemical process tank has a diameter of 3m. the tank has a capacity when full, of 51980 litres. if the tank is filled to 72% of its maximum capacity with a mixture of liquids with a combined density of 1063 kg/m3 determine the pressure at the base of the tank
Welcome to PF. Their are people here much smarter and more learned that I, and in order to receive help it is expected that the poster show some work on his/her questions.
I'll get you started on the first one...
Use this nice kinematic equation to solve for "a".
v_{f}^2 = v_{i}^2 + 2ad
You know everything but "a".
Jameson
some tip for the second q:
72% of capacity should also mean 72% of the height. You have the diameter and capacity(volume) of the cylinder therefore you can find its height.
Plug in pressure = hpg
72% full it is 37,425.6 litres
height is (51980 / 1000) / 7.1 = 7.3
(i'm not sure if i am doing this right)
i know that pressure= force/area and that density = mass/volume i just don't know how to apply it to the problem
v2= u2+ 2ad
v2-u2=2ad
v2-u2/2 = ad
v2-u2/2d= a? (i don't think that's correct I am not sure)
pressure = force/area --- 1
force in this case is the weight of the volume of liquid which is
force(weight of liquid) = mass * g
= density of liquid * volume * g
= density of liquid * area * height of liquid * g --- 2
sub 2 into 1 :
pressure = (density of liquid * area * height of water * g) / area
= density of liquid * height of liquid * g
= p*h*g (simplified - this equation can be used for finding pressure in liquid at different height)
jhaywood said:
v2= u2+ 2ad
v2-u2=2ad
v2-u2/2 = ad
no, it should be
v2-u2=2ad
(v2-u2)/2 = ad
(v2-u2)/2d= a?
For qn1(a) To make this simpler, you can actually draw a velocity time graph to get u'r time knowing the area under the graph is the distance travelled.. After finding the time, u can use the formula a = v - u / t to get acceleration.
For the 2nd part to qn 1, u can find the deceleration by using the same formula in a
For qn 2, first, juz know that P = pgh .. Where the density is =1063Kg/m^3, g =9.81m/s^2 and the height 5294m
