Help Physics (I think its free fall)
The discussion revolves around calculating the time it takes for liquid squirted upward from a syringe to return to its original level and determining its maximum height. The initial calculations suggested a return time of 0.30 seconds and a maximum height of approximately 0.11 meters. However, a correction was noted regarding the use of the initial velocity and the conditions at the peak of the trajectory. The correct approach involves recognizing that the initial velocity is not zero at the peak. Overall, the calculations were mostly accurate, with minor adjustments needed for precision.
coriimon
A doctor, preparing to give a patient an injection, squirts a small amount of liquid straight upward from a syringe. If the liquid emerges with a speed of 1.5 m/s
how long does it take for it to return to the level of the syringe?
what is the maximum height of the liquid above the syringe?
I got .30seconds to return to the level of the syringe
and the max height at around .11 meters
am I right?? just want to make sure
If you show what equations you used and how you got those answers, it's easier to check your work.
whoops sorry
I found the time it takes to return to the level of the syringe by using this equation
v=v(initial)=at
1.5m/s=0m/s+(9.81m/s^2)(t)
t=.15 seconds
to account for the time to return to the syringe I multiplied t by 2 so t=.30 seconds
to find the maximum height I used the equation
v^2=V(initial^2 +2a(x-x(initial))
2.25=19.62x
.11 m
coriimon said:
v=v(initial)=at
t=.15 seconds
I agree with both your final answers, but if I were grading this I might knock off a point here.
If you're finding the time it takes to reach the top of the trajectory, v is not 1.5 m/s there, as you've indicated. Also, the initial velocity isn't 0.
If you're finding the time it takes to drop from top of the trajectory, then the equation is okay ... provided you meant to use down as the + direction.
But it would only be a minor deduction. You pretty much got it on the nose.
