Help Solving for X (Easy I think)
  • Thread starter Thread starter Magnawolf
The equation sinxcosx + 1/2sin2x = 0.0392 poses challenges for finding an analytic solution. Numerical methods are suggested for approximating the solution since rewriting the left-hand side in terms of sin(x) or cos(x) proves difficult. A clarification on whether 0.0392 is an exact value or an approximation is needed. The equation can be transformed into a single trigonometric function of 2x, allowing for a symbolic solution. Ultimately, a calculator may be required for precise evaluation of x.
Magnawolf
sinxcosx+\frac{1}{2}sin2x = 0.0392
I can't figure out how to solve for x on this one...
I tried sin2x = cosxsinx but still can't get anywhere.
In future posts, don't discard the homework template.
For this problem, I don't see an easy analytic solution that would allow writing the left-hand side in terms of either sin(x) or cos(x). Having said that, there are lots of numerical methods that would give an approximate solution.
Hopefully you mean ##\sin(2x) = 2\sin x\cos x##. Were you given the right side as .0392 or is that a decimal approximation to what you were actually given? Anyway, calling that constant ##k##, you can write your equation as$$
\frac{\sin(2x)}{2} + \frac 1 2(\frac{1-\cos(2x)}{2})=k$$ $$
2\sin(2x) + 1 - \cos(2x) = 4k$$ $$
\frac 2 {\sqrt 5}\sin(2x) - \frac 1 {\sqrt 5}\cos(2x) = \frac {4k-1}{\sqrt 5}$$
You can write that as a single trig function of ##2x## plus a phase angle using an addition formula. You will at least symbolically be able to solve for ##x## although you may need a calculator to evaluate it exactly.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
