Help Solving Two Proofs - Tan X + Cot X = (Sec X)(Csc X)
  • Thread starter Thread starter chase222
    Proofs
The discussion focuses on solving two trigonometric proofs: tan x + cot x = (sec x)(csc x) and tan^2 x - sin^2 x = (tan^2 x)(sin^2 x). For the first proof, participants suggest rewriting the left side and combining terms, ultimately leading to the identity sin^2 x + cos^2 x = 1. In the second proof, the left side is factored and simplified, revealing a relationship that simplifies to cos^2 x = cos^2 x. The conversation emphasizes the importance of careful manipulation of terms in trigonometric identities. Overall, the participants are working towards a clearer understanding of these proofs using sine and cosine.
chase222
I need help solving 2 proofs:
I changed the left side to:
tan x + 1/tan x = (sec x)(csc x)
then crossed out the tan:
1 = (sec x)(csc x), but I got stuck there.
The next one I had trouble with was:
I saw the left side being a^2 - b^2, so I factored it into:
(tan x + sin x)(tan x - sin x) = (tan^2 x)(sin^2 x)
I then changed the tan into sin/cos:
((sin x/cos x) + sin x)) ((sin x/cos x) - sin x)) , but got stuck there.
Can you help me solve these proofs?
Try to write everything in terms of sine & cosine...You'll get them easily.
Daniel.
So for the second one:
(sin^2 x/cos^2 x) - sin^2 X = (sin^2 x/cos^2 x)(sin^2x)
So on both sides so the sin^2 x cancel, leaving it like:
cos^2 x = cos^2 x?
And for the first one:
I changed it to:
sin x/cos x + 1/(sin x/cos x) = (1/cos x)(1/sin x)
What would I do from here?
Bring it to the same denominator (in the LHS) and after simplifying the denominators,u'll find
\sin^{2}x+\cos^{2}x =1
Daniel.
"crossed out the tan" is not a mathematics term! I'm serious- think about exactly what you are doing there. tan x+ 1/tan x is NOT equal to 1 for all x!
cos^2 x = cos^2 x?
Okay, sin^2 x/cos^2 x) - sin^2 x= (sin^2 x)((1/cos^2x) - 1) so canceling sin^2 x leaves (1/cos^2 x)- 1 = sin^2 x/cos^2 x
That is NOT "cos^2 x= cos^2 x" but if you multiply both sides by cos^2 x you get something almost as easy.
