How Many mg/l Are in a 3% Sodium Hypochlorite Solution?
  • Thread starter Thread starter wilsonctj
    Chemistry
To determine the concentration of sodium hypochlorite in a 3% solution, the formula weight of sodium hypochlorite (NaClO) must be calculated. Additionally, the density or specific gravity of the solution is required, which can typically be approximated to that of water for a 3% solution. It's important to note that sodium hypochlorite can decompose into sodium chloride and sodium hydroxide, and the solution must remain alkaline to prevent rapid decomposition into chlorine. Understanding these factors is crucial for accurate calculations.
wilsonctj
Hi
I need to work out how many mg/l of Sodium Hypochlorite there are in a 3% Solution
Any help (inc workings) would be greatly appreciated!
Regards
Chris
Chemistry news on Phys.org
This goes in the Homework Problems section.
Is this for a commercially manufactured solution? Sodium hypochlorite decomposes and may yield sodium chloride as it decomposes, or maybe there is sodium chloride and also sodium hydroxide as a result of the manufacturing conditions. Note, the solution needs to be alkaline otherwise will decompose very quickly into chlorine. You can calculate for yourself the formula weight of NaClO and you may need the density or specific gravity of the solution, which you should measure yourself.
Basicly what I only meant to say was, you calculate the formula weight of the compound, and you also need to have a measurement of the specific gravity or density; then you can calculate what you asked.
3% solution is diluted enough so that you may - as a first approximation - safely assume its density is that of water.
