Help With Electrical Engineering Resistance Measurement
The discussion centers on a beginner in electrical engineering seeking help with resistance measurement techniques after struggling with lab instruction. Participants suggest using a digital multimeter (DVM) to measure resistance, emphasizing the importance of connecting resistors correctly and selecting the appropriate range on the DVM. They clarify that resistance values should be measured between specific points and provide guidance on interpreting the readings, including a sample measurement of 0.463 kOhm for a 470 Ohm resistor. The conversation also touches on resistor tolerances and the significance of understanding color codes for identifying resistor values. Overall, the thread serves as a resource for practical measurement advice and foundational concepts in electrical engineering.
Agent
Hey, I'm just starting out Electrical Engineering but I need some help. (edit) My Lab prof didn't explain to well. A lot of us feel confused by the way he teaches. I would switch lab prof but it is too late. Anyways, if someone can help me out, show me how its done, I would really appreciate it. Heres it is:
http://img441.imageshack.us/img441/3839/untitled1cd.jpg
Thanks in advance.
Edit: sorry, fixed.
Looks straighforward enough. What are you going to use to connect the resistors? Will you twist the leads and solder them, or do you have a wireless breadboard that you can plug them into? Once they are connected, turn on your DVM and put it on a resistance measurement setting. It may have an Autorange setting for resistance, where it figures out the right order of magnitude to use in the test, and then it displays the resistance in kOhms or MegOhms or Ohms, etc. If it's an older DVM it may not have Autoranging capability. In that case, you have to guess the total resistance (resistances add in series, right?), and set the DVM resistance range to a range that is >= that total value.
When using the DVM, just connect the leads to the two points you want to test (in this case the indicated points between the resistors).
BTW, you might want to tone down the badmouthing of profs here on PF. Probably a lot of the folks who stop by to help out are profs and TAs...
Agent - since the setting determines the highest reading the meter can read (limited by the 1 digit on the display) you should be able to figure this out: Does 199 ohms or less cover the readings you should see?
I get .463 for the first one. Is that correct? I will just ask my prof (another one) on Thursday if I can't figure it out.
That would be 0.463kOhm, which is within 1.5% of the 470 Ohm resistor for the first measurement. 470 Ohms is a 5% tolerance resistor, so your measurement is reasonable.
All of the resistor values in your sketch are 5% values, except 10 Ohms, which is in both the 5% and 1% tolerance resistor series. Usually you would write it as 10.0 Ohms if it were a 1% tolerance resistor though, so my guess is that all of your test resistors are 5%.
Quiz question -- how can you tell whether a resistor is 1% or 5% tolerance by looking at the color code?
Quiz question -- what are the value sequences for 1% and 5% resistors? It's handy to keep a list of both series in your notes, BTW. If you are calculating resistor values for a bias network or something, after you calculate the ideal values, you can refer to your notes to see what a real resistor value is that is close to your ideal value.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
