How can I design a spark ignition system with a wider energy delivery range?
Designing a spark ignition system with a wider energy delivery range than typical MSD systems, which are limited to about 10 mJ, poses challenges in achieving a range from 5 mJ to 1 J. A proposed solution includes measuring spark energy to quantify performance improvements, as seen in a referenced project. The discussion highlights the significant power requirements for high-energy sparks, with calculations indicating a need for 533 watts at 44 amps for an 8-cylinder engine at 8000 RPM. It is noted that while higher energy may not yield performance gains beyond certain thresholds, multiple discharges can enhance starting performance. Overall, the feasibility of such a system must consider both energy delivery and the impact on the vehicle's electrical system.
mfig
Hello,
I would like to design a spark ignition system with a wider range of energy delivery than a typical MSD system. On the MSD systems I have looked at, they are limited to about a 10 mJ range, but I need to go from, say 5 mJ to 1 J if possible. Does anyone know of a packaged system like that or how to modify an MSD system to deliver a wider range?
Thanks
here's an interesting project, a meter to measure spark energy.
If you're "hopping up" factory systems you'll need a way to quantify results.
http://worldphaco.net/uploads/THE_SPARK_ENERGY_TEST_MACHINE.pdf
1 joule per spark X how many sparks per second ?
How do you plan to power it ?
8 cylinders @ 8000 RPM X 1 joule/spark = 32000/60 joule/sec = 533 watts = 44 amps@12 volts
When I worked in the aftermarket automotive electronics industry I recall reading that the typical HEI ignition system that GM used for many years was about as much spark as anything typically needed. Any more energy beyond that showed no gain in performance. Now this is of course up for debate and I am just repeating what I have heard. I will say that how 'performance' is defined is also up for debate. I have an MSD system on a car and I suspect that the multiple discharges improves starting and in my opinion this is an improvement in performance. I didn't do the math that Jim Hardy did but if you draw 44 amps from your electrical system do you think maybe the power it takes to supply this spark will load the alternator to the point that you are in fact losing performance?
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
