Troubleshooting Log Formula for ILS DDM Calculation | Expert ATS Assistance
  • Thread starter Thread starter mcalves
    Formula Log
mcalves
Hello
Im studying an ATS equipment known as an ILS. One of the formulas to determine the DDM is :
E2 = E1 log-1(db/20)
When I try entering log-1, the calculator displays Math Error. What am I doing wrong?
Thanks for the help in advance
The logarithm is not defined for negative numbers.
Are you sure that "log-1" means log(-1)?? Look more closely at the formula.
Its log to the negative power of 1, I don't know how to format that below.
the funny thing is that there are examples in the book with the answer. For example:
Ec = 2.5log-1 (-3/20) = 1.77
Ecs = 1.0log-1(-3/20) = .707
Ess = 0.155log-1(-3/20) = 0.109
\log^{-1}x = \frac{1}{\log{x}}<br />
Click on the LaTeX to see the code.
thanks neutrino, but what about that (-3/20) that will give me a negative. Logs don't work that way right?
They don't. Are you sure db is negative?
its interesting you say that because the its starts out with a 3db then they change it to a -3. I'll type the whole thing below...
Where:
E2 = before attenuation
E1 = after attenuation
The upper attenna signals exiting Z6 at output 2 are attenuated by 3db. Letting "A" equal .31, the Ess signal in the upper antenna would be .5A or .155 prior to Z6. So the equation becomes:
E2 = .155log-1(-3/20) = .109
What the heck does that mean ^^
Sorry, I'm clueless. Maybe someone familiar with this topic (at the Electrical Engineering forum) will be able to answer your question.
Thanks neutrino. I'll give it try. :)
