Help with multiloop circuit problem
  • Thread starter Thread starter lcybulsk
    Circuit
The discussion revolves around solving a multiloop circuit problem involving two parallel batteries with a given emf and internal resistance connected to a resistor R. Participants emphasize the importance of correctly applying Kirchhoff's loop and junction rules to determine the current through the load resistor. There is confusion about whether the currents through the batteries and the resistor are the same, which is clarified by suggesting the use of Thevenin's equivalent to simplify the analysis. The correct approach involves writing out the loop equations and ensuring compliance with the junction rule. Ultimately, understanding these principles is crucial for maximizing power dissipation in the resistor.
lcybulsk
In Fig. 27-50, two batteries of emf ε = 12.0 V and internal resistance r = 0.300 Ω are connected in parallel across a resistance R. (a) For what value of R is the dissipation rate in the resistor a maximum? (b) What is that maximum?
The figure can be seen here...problem 27.39 http://www.cabrillo.edu/~cfigueroa/4B/4Bproblem_sets/Chap27_problems.pdf
V=IR
Loop/Junction Rules
P=I^2R (Internal resistance dissipation)
I used the loop rule to find an equation for both emf devices and resistor (same emf, so same equation i presume)
E - IR - Ir = 0
However when i get to the junction rule and finding an equation for current, i cannot figure out if the current in the emf and the current in the resistor are the same
If the currents are the same i did E- (R-r)I=0, then solved for I
Once i found I as I= E/(R-r) i substituted it in the equation for power P=I^2R in order to get a function where i can differentiate it
P= (E/(R-r)^2R
Is this correct? I am confused on if i can assume the currents are the same in the resistor R and the batteries
You might be better off finding the Thevenin equivalent of the two batteries first. That will simplify things considerably since you'll be dealing with a single source and a single internal resistance.
If the above paragraph leaves you mystified because you've never heard of Thevenin or his equivalent, then I suggest that you write out the Kirchoff loop equations. Solve for the current through the load resistor.
When you write: E - IR - Ir = 0, you are assuming that the current through each battery is the same as the current through R. That violates the junction rule.
