Help with Partial Fraction Decomposition
akbar786
\int 1/(x^{2}+4x+5)^{2}
I am using partial fraction decomposition
1/(x^{2}+4x+5)^{2} = Ax+b/(X^2+4x+5) + Cx+D/(x^2+4x+5)^2
1 = (Ax+b)(X^2+4x+5) + Cx+D
When i multiply through to find the values for A and b and c i get zero because there is no X^3 or x^2 or x on the left side. Am i doing something wrong or do i need to use another method to solve this integral?
The integrand is already in expanded form. You need to use another method. Start by rewriting the denominator in the form (x+a)2+b2, and then use a trig substitution.
so when there is only dx sitting on the top i cannot use partial fraction decomposition? How can i tell if its already in expanded form. On the directions of this problem the TA said to use PFD but it clearly does not work.
If you use partial fraction decomposition, I'm reasonably certain that you'll end up with exactly what you started with. Take vela's advice.
You want to use partial fractions when you have distinct factors on the bottom. For example, you would use the method if the denominator was (x+1)(x2+1). On the other hand, if you had just (x+1)2 in the denominator, it's already in the form you want it in. For instance, if you tried to expand, 1/(x+1)2, you'd write
\frac{1}{(x+1)^2} = \frac{A}{x+1} + \frac{B}{(x+1)^2}
But the LHS already looks just like the second term on the RHS with B=1. Similarly, in this problem, the integrand is already in the form of a possible term you'd have after doing the partial fractions expansion, which is why you're just ending up with what you started with.
Your TA probably just glanced at the problem and told you to use partial fractions before thinking about it. When you see that type of integrand, partial fractions is one of the first methods that comes to mind.
oh, i see what you mean. Basically if there is only one type of polynomial squared or cubed in the denominator then i can't use partial fraction but if suppose there is (x+2)(x-1)^2 in the denominator then i could use partial fractions and expand the as a/(x+2) + b/(x-1) + c/(x-1)^2 right? Also, in order to solve the first question i posted should i complete the square for the denominator in order to get it into a trig substitution format?
Yes and yes.
After i complete the square i end up with dx/((x+2)^2+1)^2. I substitute u = x+2 , du = dx
so i get the integral du/(u^2+1)^2. Then i got u = tan theta, du = sec^2(theta) d(theta) and i replace that in the integral as sec^2(theta) d(theta)/(tan^2(theta) +1)^ and i get after i substitute sec^2 in the bottom for tan^2 + 1 and then cancel the sec^2 on the top i end up with 1/sec^2, which is cos^2. Am i on the right path so far?
Yup!
