Help with proving a transfer function?
The discussion focuses on deriving a transfer function involving impedances Z1, Z2, and Z3. The user initially struggles with the expression for Zout and attempts to relate it to Zg. Another participant clarifies that Zout can be calculated using the formula Z2 || Z3, leading to the equivalent impedance across Vo. They explain that the total impedance seen by the source, Vg, is the sum of Zo and Z1, which is derived from voltage division principles. The conversation emphasizes the importance of correctly applying these principles to arrive at the correct transfer function.
Chandasouk
http://img195.imageshack.us/i/89020004.jpg/
I cannot get the Z2Z3 to appear in the bottom.
I'm saying Zout = Z2 || Z3 so that gives Z2Z3/Z2+Z3 and Zg = Z1
Then H(s) = Zout/Zg = Z2Z3/Z1Z2+Z1Z3
What am I doing wrong?
You can attack this problem using voltage division. You can get the equivalent impedence across Vo and then divide it by the total impedence seen by the source, Vg.
So:
The voltage seen by Vo:
Zo = (Z3)(Z2)/(Z3+Z2)
The voltage seen by Vg:
Zi = Zo + Z1
So when you divide Zo/Zi and simplify you get the correct answer. Hope that helps! Let me know if you need further explanation.
Can you explain why Zi = Zo + Z1? I always thought voltage division was
Vn = Vtotal(Rn/Rtotal)
Where V is voltage and R is resistance. In our case, we would just replace the R's with Z's for impedances but I'm still not sure how you got Zi = Zo + Z1 from that
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
13K
