Help with Taylor Series/Maclaurin Series Question
  • Thread starter Thread starter student93
    Series Taylor
student93
Problem is attached in this post.
I've tried using Maclaurin Series for e^x, and get the term -x^10/5!, however f(0) = 0 which is not the correct answer. Also taking 10 derivatives seems too burdensome of a task etc. Is there any other method to solve this problem?
The answer is D. -10!/5!
\displaystyle f^{(10)}(x) = \frac{d^{10}}{dx^{10}}f(x)\ .
It's not \displaystyle \left(f(x)\right)^{10}
I don't understand what you mean?
It's the tenth derivative ... evaluated at x = 0 .
I know that, but solving for 10 derivatives seems like an impractical way to solve this problem. Is there any other method to solve this problem?
Solving for 10 derivatives is not really that difficult -- using the MacLaurin Series.
What is the 10th derivative of x6, for example?
10th derivative of x^6 =0, I've tried Maclaurin, and got my 10th powered term as -x^10/5!, but f(0)=0 and the answer is -10!/5!
What is the 10th derivative of x10 ?
sammys said:
what is the 10th derivative of x10 ?
3,628,800
student93 said:
3,628,800
Yes, that's 10! . Right.
Even if x = 0.
So do I take the derivative of -x^10/5!?
What is the MacLaurin series for ##e^{-x^2} \ ? ##
The 10th derivative of of the first 5 terms, those with power, 0, 2, 4, 6, 8, are all zero, right?
SammyS said:
What is the MacLaurin series for ##e^{-x^2} \ ? ##The 10th derivative of of the first 5 terms, those with power, 0, 2, 4, 6, 8, are all zero, right?
Yes:
1 - x^2 +x^4/2! - x^6/3! +x^8/4! - x^10/5! ... etc.
student93 said:
Yes:
##1 - x^2 +x^4/2! - x^6/3! +x^8/4! - x^{10}/5!+x^{12}/6! \dots ##
The 10th derivative of that ... evaluated at x = 0 ?
I understand it now, thanks for the help. (Since the f^(10)(0)/10! = -1/5! etc.)
Good.
That notation is a bit strange.
If ##f(x) = 1 - x^2 +x^4/2! - x^6/3! +x^8/4! - x^{10}/5!+x^{12}/6!\ \dots##
then the 10th derivative is:
##f^{(10)}(x) = - 10!/5!+(12!/2)x^{2}/6!\ \dots##
Then ##f^{(10)}(0) = - 10!/5!+(12!/2)0^{2}/6!\ \dots =- 10!/5!##
