Help with using the first derivative
  • Thread starter Thread starter meeklobraca
    Derivative
meeklobraca
Use the first derivative to determine where the graph of y = x/(x^2+1) is rising.
Ive figured the derivative to be (1-x^2) / (x^2+1)^2 and I know that the derivative > 0 will tell me where the graph is rising. I am just not sure how to figure that out. Do I need to simplify my derivative a bit more to make it work?
The denominator will always be positive, so all you need to do is determine where the numerator is positive, and where negative. Factor 1 - x^2 and see where it is zero, and where positive, and where negative.
"Factor 1 - x^2 and see where it is zero, and where positive, and where negative."
Im not sure I know what you mean here. Factored form it is (x-1)(x+1)
Its 0 when x = +-1 , positive for 0<x<1 negative for (-infin,0) (1,infin)?
i think you may have missed the effect of one of the factors...
you could say (1-x^2) is +ve:
when
1-x^2 >0
implying
x^2 < 1
"Factored form" is NOT (x- 1)(x+ 1), it is (1- x)(1+ x).
And the graph of y= (1-x)(1+x)= 1- x2, is a parabola opening downward and so y is positive for x between -1 and 1. I don't where you got the "0" in "0< x< 1". Was that a typo?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
