Help with Vectors: Calculating Displacement, Speed & Velocity
  • Thread starter Thread starter jesstryin
    Vectors
Darryl's journey involves driving 14 km east, 6 km north, 12 km at 15° east of north, and 2 km at 65° east of north, totaling a distance of 34 km. The calculated displacement is approximately 26.4 km, with components of 18.9 km east and 18.4 km north. Average speed is determined to be about 13.5 m/s, while average velocity is approximately 10.5 m/s. There is some confusion regarding the direction of the displacement, with discussions suggesting it could be expressed as either 26.4 km N 54.9° E or 26.4 km E 54.9° N. Clarification on vector direction is essential for accurate calculations.
jesstryin
Hi everyone, my problem is this:
Darryl drives his load of tomatoes 14.0 km [E], 6.0 km [N], 12.0 km [ N 15° E], and then 2.0 km [N 65° E]. This takes him 42 minutes.
a) Calculate Darryl's distance and displacement. Draw a diagram and show your work.
b) Calculate Darryl's average speed and average velocity (record your answer in m/s).
sinb/b =sinC/C
A. 14 km + 6.0 km + 12.0 km + 2.0 km = 34 km
Total Distance is 34 km = 34,000 m
D (east) = 14 + 12 * sin15 + 2 * sin65 = 18.9 km
D (north) = 6 + 12 * cos15 + 2 * cos65 = 18.4 km
C2 =√ a2 + b2
D = √(18.9km² + 18.4km²)
= 26.4 km
My problem is that I think I miscalculated the displacement (east), for the speed and velocity calculation I did this:
B.
Vav (speed) = 34km / 42 min = 34,000 m / 2520 s
Vav= 13.49 or 13.5 m/s
Vav = 26.4 km / 42 min = 26,400 / 2520
Vav (velocity) = 10.47 or 10.5 m/s
I just need clarification for displacement, so that I can accurately calculate the velocity.
Hi jesstryin. Welcome to Physics Forums.
Your method looks right, though I haven't checked your arithmetic.
Likes 1 person
Thank you! Could you let me know if I got the answer correct for displacement, I feel like I'm missing a step and need the displacement to calculate the right velocity. Thanks so much!
Your displacement magnitude calculation is correct.
Don't forget that vector quantities are specified by a magnitude and a direction.
So, is the answer for displacement 26.4 km N 54.9 degrees E ? Or is it 26.4 km E 54.9 degrees N ? I think it is the former, but I am not sure.
Thank you for all the help I appreciate it!
I believe this link explains that.
http://www.compassdude.com/compass-units.shtml
