Help with Work & Power Problem: 60kg Student on Incline
A 60kg student running up a 4-meter incline with a height of 2.5 meters needs to calculate his power output while maintaining constant velocity. Initially, the student incorrectly assumed no work was done due to zero acceleration, leading to a power output of 0 W. However, the correct approach involves recognizing that the student must perform work against gravitational force to gain potential energy while ascending. The power output is determined by the change in energy over time, resulting in a calculated power of approximately 326.67 W. Understanding the relationship between work, energy, and power is crucial for solving such physics problems.
jCarlson
Hey everyone. I'm new to this site and was wondering if u can help me with a work and power problem. :smile:
Question:
A 60kg student runs at a constant velocity up the incline described in the diagram in 4.5s. Calculate the power output of the student.
The diagram was a picture of a right-angled triangle with hypotenuse length 4 meters. The hypotenuse is the ramp, and the ramp is raised to a height of 2.5m (also the length of the vertical leg). The student is running up the ramp.
My Work:
Since he is running at constant velocity, acceleration = 0m/s/s.
F=ma, so F = 0 N.
W=Fd, so W = 0 J.
P=W/t, so P = 0 W.
The answer from the back of the book was P = 326.67 W.
I know the student is doing work in terms of his muscles having a tensional force, but I don't think that is the way to go with this problem at all.
Anyways, any help will be appreciated thanks.
BTW, there was no information regarding friction.
The student has to overcome some gravitational pull, thus he has to generate force. Can you determine its magnitude?
The fact that the student is doing work is pivotal to finding the power. It's easier to think of this in terms of energy. The work that the student does brings him from the bottom of the incline to the top of the incline. What type of energy (kinetic or potential) changed for the student from the bottom of the cliff to the top of the cliff? Hint: The student is assumed to keep a constant velocity throughout.
What you did was assume that since the student is not accelerating, he is doing no work. But does it really make sense to think that someone can get from the bottom of a cliff to the top of the cliff without doing any work? (I made the same mistake plenty of times, so don't feel bad.)
The student's work creates a change in the student's energy, bringing him from the bottom of the incline to the top of the incline. If the work is W, then, as you already found, power is work over time.
Another way to approach this kind of problem is to write the total energy as the sum of the potential and kinetic energies:
TE = PE + KE
If his velocity is constant, are there any changes in his KE as he runs up the hill? What can you say about his PE? And then just remember that power is the amount of energy change per unit time (per second in mks units).
EDIT -- Saketh was too fast for me -- beat me to it.
Thanks for the help, I solved the problem by thinking Power as change in energy over time.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
