How do we determine the eigenvalues of B^2 if B is Hermitian?
  • Thread starter Thread starter interested_learner
    Hermitian Matrix
interested_learner
The question was:
If B is Hermitian show that A=B^2 is positive semidefinite.
The answer was:
B^2 has eigenvalues \lambda_1 ^2, ... \lambda_n^2
(the square of B's eigenvalues) all non negative.
My question is:
Why do we know that B^2 has eigenvalues \lambda^2?
What happens if you act B^2 on the eigenvectors of B?
I am not quite sure what you mean by act, but I will assume you mean multiply together. If we take:
A= \left[ \begin{array} {cc} 1 & 1 \\ 1 & 1 \end {array} \right]
Then the eigenvalues are 2 and 0.
Then eigenvectors are:
B = \left[ \begin{array} {cc} 1 & 1 \\ 1 & -1 \end {array} \right]Then AB = \left[ \begin{array} {cc} 2 & 2 \\ 0 & 0 \end {array} \right]
Wow! The values in the matrix are the eigenvalues. Is this result general? Can we prove it?
How does that help solve the original question?
Let V be any eigenvector of B, and l be any eigenvalue.
B*V= l*V by definition. Starting from that equation you should be able to determine the eigenvalues of B^2. This is what Parlyne meant.
edit: l is the corresponding eigenvalue of V.
heres an alternative proof to show that the eigenvalues of A are all nonnegative (and thus A is positive semidefinite). let x be an eigenvector of A, and let \lambda be its corresponding eigenvalue. Then we have the following.
\lambda \langle x,x \rangle = \langle \lambda x, x \rangle = \langle Ax, x \rangle = \langle B^2 x, x \rangle = \langle B^{*}Bx, x \rangle = \langle Bx, Bx \rangle \geq 0
Oh gee! of course. it is obvious or should have been. Thank you.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
