Hiesenberg uncertainty principle, h or hbar?
The discussion revolves around the Heisenberg uncertainty principle, specifically the use of Planck's constant (h) versus the reduced Planck's constant (ħ) in the formulation of the uncertainty relation ΔxΔp. Participants explore whether these constants apply to different situations or if one is outdated.
  • Some participants note that both ΔxΔp ≥ h/2 and ΔxΔp ≥ ħ/2 are used in different contexts, leading to confusion about which is correct.
  • One participant asserts that the correct formulation involves standard deviations and states that ΔxΔp ≥ ħ/2 is the accurate expression when using standard deviation.
  • Another participant questions whether the use of different measures of spread could lead to different formulations of the uncertainty principle.
  • A later reply challenges the correctness of the physics textbook that uses h/2, stating that the inequality with ħ is the correct one.
Participants do not reach a consensus; there are competing views on the correct formulation of the uncertainty principle, with some advocating for ħ and others referencing h.
There are unresolved questions regarding the definitions of measures of spread and the contexts in which each formulation is applicable.
rash92
i've seen both:
ΔxΔp >= h/2
and
ΔxΔp >= hbar/ 2
used, and I'm not sure which is correct. my physics textbook uses h/2, but wiki and other online rescources seem to use hbar/2
do they apply to different situations? (if so, where do you use hbar and where do you use h?) or is one of them outdated?
No, the only generally correct statement is about standard devitians of two observables. For any (pure or mixed) state, one has
[tex]\Delta A \Delta B \geq \frac{1}{2} |\langle [\hat{A},\hat{B}] \rangle|.[/tex]
Since for position and momentum components in the same direction, you have
[tex][x,p]=\mathrm{i} \hbar[/tex]
you have
[tex]\Delta x \Delta p \geq \hbar/2.[/tex]
Other uncertainty relations are found in the literature from hand-waving arguments using other uncertainty measures than the standard deviation!
so if I'm understanding correctly, if you use standard deviation, it's always hbar/2,
but if you use other measures of spread then it could be different?
rash92 said:
i've seen both:
ΔxΔp >= h/2
and
ΔxΔp >= hbar/ 2
Your physics textbook is wrong, the correct inequality is the one with hbar.
  • · Replies 32 ·
  • · Replies 0 ·
