Holding down steel plate w/ multiple magnets: Does orientati
The discussion focuses on using an array of Neodym magnets to secure a steel plate on a 3D printer's heated aluminum bed. Two orientations of the magnets are compared: one with all magnets aligned and another with every second magnet flipped. The goal is to ensure the steel plate remains flat and stable, preventing movement in the XY direction. The flipped orientation is suggested to be more effective if the distance between the magnets and the steel plate is smaller than the distance between the magnets, as it enhances magnetic flux and stability. Overall, the orientation of the magnets significantly impacts the effectiveness of holding the steel plate in place.
Wookbert
The picture below shows an image of a bed from a 3d printer, which I intend to equip with an array of 15 x 3 mm Neodym magnets to hold down a steel plate. The steel plate itself is not and can not be equipped with magnets. Theres a heated aluminium bed between magnets and steel plate and the magnets are specified to withstand 150°C.
The left side shows all 12 magnet arranged with the same orientation, on the right side every second magnet is flipped. The distance between the magnet is wide enough so they don't noticeably attract/distract/disturb each other.
Question: The goal is that the steel plate lays flat (Z direction) and does not accidentally move in XY direction. Is either magnet orientation better than the other in achieving this?
The second one will be better if the distance between steel plate and magnets is smaller than the distance between the magnets. The second orientation provides return lines for the magnetic flux and leads to stronger induced magnetic fields in the plate.
Thank you!
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
