Hollow cylinder magnet making contact with the circuit
The discussion centers on the interaction between a hollow cylinder magnet and a circuit, specifically examining the electromotive force (emf) generated when either the circuit moves downward while the magnet remains fixed, or the magnet moves upward while the circuit is stationary. The participant references Maxwell's equations and the formula F = v x B to analyze the forces acting on a charge in different reference frames. The main inquiry is how to express the effects of a moving uniform magnetic field in the coordinate system of a fixed charge, particularly when the charge's velocity is zero.
  • Understanding of Maxwell's equations
  • Familiarity with electromagnetic theory
  • Knowledge of the Lorentz force law (F = v x B)
  • Basic concepts of reference frames in physics
  • Research the implications of the Lorentz force in different reference frames
  • Study the principles of electromagnetic induction and Faraday's law
  • Explore the concept of magnetic fields in motion and their effects on stationary charges
  • Investigate practical applications of moving magnets and circuits in generating emf
Physics students, educators, and professionals in electromagnetism, particularly those interested in the dynamics of magnetic fields and their interactions with electric circuits.
TwoEG
1. Circuit moves downward while cylinder magnet is fixed.
2. Cylinder magnet moves upward while circuit is fixed.
Gain emf in circuit.
All those maxwell equations...
F=v x B
[/B]
So first question is not that hard. Circuit moves in a static magnetic field. Okay. And I saw second question. Hmm. isn't it just relatively the same case as 1st one? But I've never thought of F=v x B in this way. I tried to see moving uniform magnetic field in fixed charge's coordinate. But it's just uniform magnetic field that doesn't change with time. And me, charge doesn't move at all from my perspective.
To sum up, my question is how does moving-uniform magnetic field is expressed in fixed charge's coordinate and how can I explain the forces that exerted upon this charge?
The cylinders look different. One appears to have a hole drilled in side. Other one has a slot.
Yes, but that's not main concern for me. (Maybe I should just attached another adequate picture.)
My question is, there is a magnet and a charge which moves relative to each other. In magnet's coordinate, force exerted on charge can be easily expressed via F = v x B. But how can I explain this force in this charge's coordinate? Clearly v here is zero, and in above case magnetic field is also just uniform.
  • · Replies 18 ·
  • · Replies 31 ·
