guv
- Messages
- 122
- Reaction score
- 22
- Homework Statement
- A disk of uniform mass density, mass M, and radius R sits at rest on a frictionless floor. The disk is attached to the floor by a frictionless pivot at its center, which keeps the center of the disk in place, but allows the disk to rotate freely. An ant of mass m ##\ll## M is initially standing on the edge of the disk; ou may give your answers to leading order in m/M.
The ant walks an angular displacement ##\theta## along the edge of the disk. Then it walks radially inward by a distance h ##\ll## R, tangentially through an angular displacement −##\theta##, then back to its starting point on the disk. Assume the ant walks with constant speed v.
Through what net angle does the disk rotate throughout this process, to leading order in h/R?
- Relevant Equations
- The disk will rotate $$\frac{4 m h \theta}{M R}$$
The solution is given. What makes this solution unique is that there is a net turn for the disk. The note of the solution mentions this system is non-holonomic. My question is that are there other non-holonomic examples. What makes this particular set up non-holonomic? Thanks!
