Kinetic Friction of Blocks: Mass M & 2M, 0.500m/s^2
  • Thread starter JUniTo24
  • Tags
    Home Work
In summary, the problem involves two blocks, one with mass M and another with mass 2M, accelerating at a magnitude of 0.500m/s^2 when released from rest. The goal is to find the coefficient of kinetic friction between block 2 and the table. The approach is to analyze the forces on each block separately and use Newton's 2nd law to create a system of equations to solve for μ. A diagram is provided for visual aid.
JUniTo24
When the three blocks are released from rest, they accelerate with a magnitude of 0.500m/s^2.Block 1 has mass M, block 2 has 2M.What is the coefficient of kinetic friction between block 2 and the table?
Please provide a complete statement of the problem (include a diagram, if possible), show your work, and point out where you are stuck.
Diagram of problem
http://i260.photobucket.com/albums/ii15/Jose243_photo/diagrama.jpg"
Take each mass in turn, analyze the forces on it, and apply Newton's 2nd law. You'll get three equations that you can solve together to find μ.
1. What is the definition of kinetic friction?
Kinetic friction is the force that opposes the motion of an object as it moves across a surface.
2. How is kinetic friction different from static friction?
Kinetic friction occurs when an object is already in motion, while static friction occurs when an object is at rest and trying to be moved.
3. How does mass affect the kinetic friction of blocks?
The greater the mass of an object, the greater the force of kinetic friction will be. This is because the weight of the object is a determining factor in the strength of the frictional force.
4. What is the relationship between the coefficient of friction and the kinetic friction of blocks?
The coefficient of friction is a constant that represents the amount of friction between two surfaces. The higher the coefficient of friction, the greater the force of kinetic friction will be.
5. How does the speed of the blocks affect the kinetic friction force?
The speed of the blocks does not have a direct effect on the force of kinetic friction. However, as the speed of the blocks increases, the force of kinetic friction will also increase due to an increase in heat production from the frictional force.
