Homework hellp. coefficent of friction.
  • Thread starter Thread starter briiannnaa04
    Friction Homework
An 18.0 kg box on a 37.0-degree incline accelerates at 0.270 m/s², prompting a calculation of the friction force and coefficient of friction. The acceleration due to gravity along the incline is calculated as 9.8 sin(37), resulting in a theoretical acceleration of 5.9 m/s² without friction. Using Newton's laws, the frictional force is derived from the difference between the gravitational force and the actual acceleration. The normal force is determined by the weight of the box multiplied by cos(37), leading to the equation for the coefficient of friction. The final calculation yields a coefficient of friction of approximately 0.719, confirmed through a free body diagram analysis.
briiannnaa04
An 18.0 kg box is released on a 37.0 degree incline and accelerates down the incline at 0.270 m/s/s. Find the friction force impeding it's motion. How large is the coefficient of friction?
Ff=uFn
I have no idea how to do this.
Can you do the problem if there were no friction, that is just asking for acceleration down an inclined plane?
ohh, maybe how can i do it without friction though?
Well you can't but the principles used apply:
In other words the acceleration from gravity along the surface of the ramp is sin(theta) * g. It is not 9.8. So if there were no friction a=9.8 sin(37). What is this come out to be?
5.9?
OK. Now we are told that the acceleration is not 5.9 but a measly 0.27.
So let's write an eqn using Newtons laws.
ma=sum of all forces ? is the frictional force
18.0*0.27=18*5.9-? Let's not worry about the components that make up ? yet. Can you compute ?
4.86=106.2-? so 101.34? or is there more than one other force?, Thank you for helping I'm sorry I'm really bad at physics.
Should be 18(5.9-0.27)
Ok now the tricky part. This frictional force is equal to the normal force * u where u is the coefficient of friction.
On level ground normal force is just opposite the weight. But on a plane it is
weight* cos(37)
So normal force is 18*9.8 cos (37). Let's call this N.
Then we have N*u=the same ? as you calculated before. can you get u?
176.4 cos(37)=140.9
N*u=101.34
140.9u=101.34
so u=.719
By george I think you got it. It makes more sense with a free body diagram.
Thank you so much!
