Calculating the Physics of a Windlass System
  • Thread starter Thread starter Dep87
    Physics System
The discussion focuses on calculating various aspects of a windlass system involving a falling bucket of water and a solid cylinder. Key points include determining the tension in the rope during the fall, the speed of the bucket upon impact with the water, and the time it takes to fall. Additionally, the forces acting on the cylinder and the relationship between the bucket's acceleration and the forces involved are examined. The moment of inertia of the cylinder and the forces exerted on it by the axle are also critical to understanding the system's dynamics. Overall, the calculations involve applying principles of physics, including torque and angular acceleration, to analyze the motion of both the bucket and the windlass.
Dep87
I don't know how to do this.
A bucket of water of mass m_1 is suspended by a rope wrapped around a windlass, that is a solid cylinder with diameter d with mass m_2. The cylinder pivots on a frictionless axle through its center. The bucket is released from rest at the top of a well and falls a distance h to the water. You can ignore the weight of the rope.
1. What is the tension in the rope while the bucket is falling?
Take the free fall acceleration to be g.
2. With what speed does the bucket strike the water?
3. What is the time of fall?
4. While the bucket is falling, what is the force exerted on the cylinder by the axle?
The cylinder has a moment of inertia of __________
The center of mass of the cylinder does not move, so the total force acting on the cylinder is __________
The cylinder does rotate with angular acceleration so there must be a _______________ that comes fom the ___________
The bucket accelerates downward in response to the net force that is the combination of ____________ and ________
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
14K
