What Is the Acceleration Ratio of a Disk to a Hoop Rolling Down an Incline?
  • Thread starter Thread starter Mac13
    Disk
A uniform solid disk and a uniform hoop rolling down an incline from rest exhibit different speeds at the bottom, with the disk achieving a velocity of sqrt(4/3hg) and the hoop sqrt(hg). The discussion centers on determining the ratio of their accelerations, a_disk to a_hoop. The calculations reveal that the acceleration ratio is 4/3, derived from the relationship between their final velocities and the distance traveled. The importance of rolling without slipping is emphasized, as it affects the time taken to reach the bottom. Ultimately, the correct ratio of their accelerations is confirmed to be 4/3.
Mac13
hoop and disk rolling(help please)
ok I've been looking at this forever and can't get it...dont know what to do..i would appreciate it if someone could help
A uniform solid disk and a uniform hoop are
placed side by side at the top of an incline of
height h.
If they are released from rest and roll with-
out slipping, determine their speeds when
they reach the bottom. (here i found the speeds to be
velocity disk = sqrt(4/3hg)
velocity hoop = sqrt(hg)
now here is my problem
What is the ratio of their accelerations as they
roll down the incline, a_disk / a_hoop?
1. 4/3
2. 2
3. sqrt(3)
4. sqrt(3/2)
5. 1/2 xxxx
6. sqrt(4/3)
7. 1/3 xxxx
8. 3
9. 3/2
10. sqrt(2)
..ps - the ones i put an xxxx out the right on i figured couldn't be it since the velocity of the disk is greater the acceleration of the disk(top value) must be greater
1. 4/3
2. 2
3. sqrt(3)
4. sqrt(3/2)
5. 1/2 xxxx
6. sqrt(4/3)
7. 1/3 xxxx
8. 3
9. 3/2
10. sqrt(2)
Write the acceleration for each
disk: sqrt(4/3hg)/t
hoop: sqrt(hg)/t
Now divide them and see what you get.
disk/hoop = sqrt(4/3) which is answer 6
You remember how to divide radicals right?
ShawnD's answer isn't quite correct. Because the two objects are rolling down with a different acceleration, there is a difference in time in order to get to the bottom. However, regardless, we do know the equation
v_f^2 = v_i^2 + 2ad
In case LaTeX doesn't work, v_f^2 = v_i^2 + 2ad,
both initial velocities are zero, so we solve for a in terms of v_f and get
a = \frac{v_f^2}{2d}
a = v_f^2/(2d)
Since d is the same for both, we can compare these two velocities, so our answer will come from
a1/a2 = (v_f1/v_f2)^2 = (Sqrt[4/3hg]/Sqrt[hg])^2 = Sqrt[4/3]^2 = 4/3
cookiemonster
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
